20 Most Recent Samsung N145-JP01US Netbook Questions & Answers
Hello Kate, please use these links:
http://www.samsung.com/us/support/downloads/NP-N145-JP01US
or
http://www.samsung.com/us/support/owners/product/NP-N145-JP01US
Samsung... | Answered on Mar 15, 2019
I'm going to assume your wifi is acting up. It does help to use proper grammar when asking a question. So we know the whole situation. It looks like your F9 key should turn it back on if that is all you are asking.
Samsung... | Answered on Aug 05, 2014
what type of lapotop
Samsung... | Answered on Mar 25, 2014
Someone may have reinstalled Windows software and removed the recovery partition. Only way to fix is to use a Windows installation disc to reinstall Windows..
You can down load a program from Microsoft, just search around a little on the Web. Try to get the one from the real WWW.MICROSOFT.com, it's probably your best choice.
Samsung... | Answered on Feb 20, 2014
Dear frnd,
Probably its battery problem but before change the battery you have confirm first its battery or Adopter problem. you need do first check the adopter to another laptop which has same charging pin . if its doesn't work with another laptop then you change the adopter but if the charger works with other laptop then you need to change your battery. try it..
Samsung... | Answered on Jan 15, 2014
If it was by Asus you could. Not sure about Samsung. Usually laptops have a seperate partition then contains the files to reinstall from scratch.
Samsung... | Answered on Jan 01, 2014
Maybe there is a short circruit in some components on that side... in that case laptop should be dissasembled, scanned and fixed properly..
Samsung... | Answered on Feb 16, 2013
OK, there are a few things to check.
1) does the power charger charge the battery? does your charging lights come on? Try and obtain a replacement charger to try (make sure yoiu use one that is rated for your laptop or you could damage the charger or your laptop. You can check the required ratings by looking at the sticker on your charger and using one with the same Volt/Amps rating.
2) try removing the battery and running the laptop just off the power supply - if this works, its likely your battery
If its none of the above, try to reset your power - remove the battery and the power supply then press and hold your power button for a minimum of 20 seconds. Reconnect the battery and charger and try again - if this works great, if not then the problem is likely to be mortherboard related. There are power regulators on the motherboard and its possible that these have blown. Take the laptop to an electronics engineer and get the fault addressed - expected repair cost would be about 50-75 GBP.
Hope this helps a little
Leon
Samsung... | Answered on Feb 09, 2013
Keyboard on what laptop or PC? is it wireless? need more information - how old is the computer its possible the motherboard went bad - moisture may be inside it if its a laptop. Doesn't seem to serious - check the connections use a different keyboard and see if that one works. Also if it came unplugged and you plugged it back in you may need to restart the computer and last if its wireless check the batteries
Samsung... | Answered on Jan 11, 2013
Sounds like you have fried your Graphics Card. Clean fan. vents, of dust. Improve air flow from bottom of laptop through fan and exit vents. Insufficent air flow will kill a Laptop, the graphics card, CPU will cook.A Laptop Cooler is a option. Avoid using on soft surfaces that prevent proper air flow.
Samsung... | Answered on Nov 24, 2012
allright,battery not charging right? it's might be that the battery itself working properly,but the system doesn't indicate that the battery is charging,because of error in the battery management software,in order to fix the software,you need to reinstall the software by using device manager,to Open device manager,right click on My Computer,and select Properties,when the Properties windows appear,click on the Hardware tab,and you will see Device Manager button,click it and Device Manager window will appear,or you can go to Start,and type Device,then select Device Manager
Expand the Battery category,and right click on Microsoft ACPI Compliant Control Method Battery listing,and select Uninstall
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
On the Device Manager taskbar, click Scan for hardware changes .
Samsung... | Answered on Aug 28, 2012
Samsung N145-JP01US Netbook Logo
63 questions posted
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
N Samsung
  • N Samsung
Most Popular Question
samsung n145 keeps switching off when
  • Computers & Internet
