Expert
- Posted on Jul 02, 2011
Re: Mac G5, what is pin set up. my computer doesn't see...
If it is not seeing it then you will need to format it properly for Mac's most hard Drives are pre-formatted for PC's.
You also need to make sure the SATA cable is plugged into the right place on the board.
SATA Hard Drives do not need a pin out. Only IDE drive's have that function.
If this is an addon drive then
Open the system drive, usually
titled "Macintosh HD." Open Applications, then Utilities and double
click the "Disk Utility" program to open it. A window will open giving a
list of all the drives currently mounted on the computer.
Select the disk that needs to be
formatted on the left. It is not possible to format the startup disk
unless the system has booted from the Install Disk. It is important to
note that formatting the startup disk will permanently erase the data
stored on the disk. If you are planning on erasing the startup disk,
back up all important files and applications.
Click on the "Erase" tab to the
right of the list of drives. The window will now display the options for
erasing the hard drive and formatting it to work on the Macintosh
computer.
Select the Volume Format from
the pop-up list. In most cases it's best to leave it at "Mac OS Extended
(Journaled)" as this is the default. This setting is the best option
for running Mac OS X. If there are other requirements for the disk, then
select the format that best suits your needs. If you have questions
about the formats, refer to the Apple user's manual.
Name the hard drive. Type a name
for the disk in the field where it asks for the name. This name will
always appear when the disk is mounted on a Macintosh computer.
Click the erase button. A window
will open asking to verify the erase procedure. Click the erase button
in this window to start the process of erasing the disk. Once the
process is complete, the drive will appear with the name it was given on
the left side of the window with the list of drives and on the desktop
of the Macintosh computer.
I got these instructions off ehow.com
