If the video does not have a freeview tuner it will not be able to record. There is a solution! All you need to do is get a freeview box, Argos have an Alba model for around £18 at the moment, Connect it via a scart to your video, if it has to scart connectors use the second one, often marked AV2. Then when you want to record, turn the box on to the channel you want to record, set the record timer, but change the channel to AV2 for the recording. That should then record the station, while you watch the other channels. If the VCR has only one scart, you can get a scart switching box, as shown below, from places such as Amazon.
