Philips AJ3980 Clock Radio Logo
A
Anonymous Posted on Jun 20, 2011
My Philips AJ3980 radio suddenly has no sound. Also, the band "MW" appears in the display and I'm unable to tune AM stations. The clock seems okay. Thanks for your help!
Gyula Lacz
Level 3:
  • Philips Master 486 Answers
  • Posted on Jun 20, 2011
Gyula Lacz
Philips Master
Level 3:
Answers
486
Questions
0
Helped
145324
Points
1242
1. Press the RADIO button to switch on the radio.
- Radio touch screen controls appears throughout
radio operation
- The radio frequency and waveband appears in the
display for 10 seconds before reverting back to the
clock display.
2. Press the BAND button to select your waveband FM/AM.
3. Tune to your station manually or automatically
by using up / down.
Here is a figure to help find the control buttons:
Please change waveband to FM.
Thanks.
gylacz
1helpful
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
How do i change the AM radio to FM?
Hello
Press RADIO BAND.AUTO PRESET until the band you want appears in the display (direct power on). Each time you press this button, the indication changes as "FM" --> "AM". Hold down TUNE + or --, until the frequency digit begins to change in the display. The player automatically scans the radio frequencies and stops when it finds a clear station. If you can't tuned in a station, press the button repeatedly to change the frequency step by step. If FM broadcast is noisy, press "MODE" until "Mono" appears on the display and the radio will play in monatural without any noise. Only strong FM signals can be decoded to stereo. OK.
3helpful
2answers
How do you auto preset radio stations?
Hello
[1] Press RADIO BAND.AUTO PRESET until the band you want appears on the display [direct power ON]. Each time you press the button the indication changes as follows. "FM" => "AM"
[2] Hold down TUNE+ or --ve until the frequency digits begin to change in the display.
The player automatically scans the radio frequencies and stops when it finda a clear station. If you can't tune in a station, press the button repeatedly to change the frequency step by step.
If FM band is noisy, press the MODE repeteadly until "MONO" appears in the display and the radio will play it monatural. If FM radio signal at your area is very weak, this type of noise may occur. OK.
Unable to tune in to programmes on LW, MW and SW bands. FM working fine
If you are experiencing bad or NONE AM (MW) reception ,if your receiver has an external antenna connection point here is the solution... It should also have a ground connection as it is rare such a point does not accompany an external antenna connection.
The problem with MW reception is the vast frequency range of the MW band as" 540-1760kHz "
means nighttime fade out, and even heavy static and distortion..( less than SW )
in order to receive a station on LW and MW bands you need to have a "Loop Antenna " that normally supplied by manufacturer..if you cant locate it ,you can buy it in any electronic store..it is a very cheap accessory..additionally both LW and MW works good in daytime with powerful radio stations in your vicinity ..espacially LW..not much stations on these days..except in Europa..MW works better and more stations come after sunset ..
SW band is a little bit different.if you really want to listen SW in depth ,and if your receiver has multiple SW bands as well ,you then need special SW antenna to be attached to your receiver..otherwise it is not worth to listen it due to heavy static and distortion on the band..,unless you want it..just for testing and to see what is available in your area pls attack a plain wire (about 1 meter ) to ext antenna plug and try to search it..if you desire to learn shortwave -Listen To The World please visit the URL below.
http://www.hamuniverse.com/shortwave.html
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us
to continue f
or Helping out the Community :)
1helpful
Brookstone SLCDv2.0 The device clearly has a Memory capability since there is a "Set" button and the display shows "Memory" when the button is pressed at a particular FM station. ...
Hi, The receiver does have an in built memory to store upto 6 channels.Please follow the steps below to set up the radio memory:- Up to six favorite radio stations (3 AM and 3 FM) may be stored in memory. the following are steps to set radio memory: 1. Press tUnInG/bAnD to select the band. 2. turn tUnInG/bAnD to locate the desired station. 3. Press the M button. the "M" indicator flashes on the LCD Display. 4. Press 1, 2 or 3 to store the selected station. 5. Press the M button again to confirm. 6. repeat steps 1-5 to set other memory stations.
Incase you would require any information do refer the below web site where you could find picture representation of the same. http://www.brookstone.com/linkedassetservlet?assetId=71937&languageId=EN
Thank you for your time and best wishes for your effort.
AM radio tuner set as MW tuner. How to switch to U.S.A. AM mode?
AM is just another name for MW. The Radio should tune to a strong signal regardless of the frequency the radio is set to. It should also sweep the entire frequency looking for stations. I'm assuming it has a channel scan setting, plus options to set a number for the station. AM/MW are very much dependent on the position of the either internal or external Ariel. If you have the radio in the wrong position or you have some electrical equipment nearby it could block the signal for the station you want, but not affect the others. Which might explain why it can't find the station you want.
Pioneer premier deh-500ub presetting stations
Storing the strongest broadcast
frequencies
BSM (best stations memory) lets you automatically
store the six strongest broadcast frequencies.
1 Use MULTI-CONTROL to select BSM in
the function menu.
2 Press MULTI-CONTROL to turn BSM on.
The six strongest broadcast frequencies are
stored in the order of their signal strength.
# To cancel, press MULTI-CONTROL again.
Tuning in strong signals
Local seek tuning lets you tune in only those
radio stations with sufficiently strong signals
for good reception.
% Press LOCAL repeatedly to select the
desired setting.
FM: OFF—LEVEL1—LEVEL2—LEVEL3—
LEVEL4
MW/LW: OFF—LEVEL1—LEVEL2
The LEVEL4 setting allows reception of only
the strongest stations, while lower settings let
you receive progressively weaker stations.
You can also perform this operation in the menu
that appears by using MULTI-CONTROL.
Selecting alternative frequencies
When the tuner cannot get a good reception,
the unit automatically searches for a different
station in the same network.
1 Use MULTI-CONTROL to select AF in the
function menu.
2 Press MULTI-CONTROL to turn AF on.
# To turn off, press MULTI-CONTROL again.
! Only RDS stations are tuned in during seek
tuning or BSM when AF is on.
! When you recall a preset station, the tuner
may update the preset station with a new frequency
from the station’s AF list. No preset
number appears on the display if the RDS
data for the station received differs from that
of the originally stored station.
! During AF search, sound may be temporarily
interrupted.
! AF can be turned on or off independently for
each FM band.
Setting the time
Setting Time
1 Press TITLE repeatedly until the time is displayed.
For details, see “Displaying the Text” (page 13)
2 Press and hold TITLE for at least 2 seconds while
The time indication will blink.
3 Turn the Rotary encoder to adjust the hours while
the time indication is blinking.
4 When the hour has been adjusted, press MODE.
5 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by pressing TITLE.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold MODE for at least 2 seconds after
setting the “hour.” Minutes will reset to “00”. If the display shows
over “30” minutes when you do this, the time will advance one hour.
Listening to Radio
1 Press SOURCE/POWER until a radio frequency
appears on the display.
2 Press BAND repeatedly until the desired radio band
is displayed.
F1 (FM1) F2 (FM2) AM F1 (FM1)
3 Press TUNE to select the tuning mode.
DX SEEK (Distance mode) SEEK (Local mode)
OFF (Manual mode) DX SEEK
• The initial mode is Distance mode.
Distance mode:
Both strong and weak stations will be automatically tuned in
(Automatic Seek Tuning).
Local mode:
Only strong stations will be automatically tuned in (Automatic
Seek Tuning).
Manual mode:
The frequency is manually tuned in steps (Manual tuning).
4 Press or to tune in the desired station.
Holding down or will change the frequency
continuously.
Manual Storing of Station Presets
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press and hold, for at least 2 seconds, any one of the
preset buttons (1 through 6) into which you wish
to store the station.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
•You will need to start from set up or you will not be able to set the mins
1helpful
Manually change radio stations?
Here is how to manually tune your radio.
1 Press the SOURCE button until a radio
frequency appears in the display.
2 Press the BAND button repeatedly until the
desired radio band is displayed.
Each press changes the band:
→ F1(FM1) → F2(FM2) → AM
3 Press the TUNE button repeatedly until "DX
SEEK" and "SEEK" disappear from the display.
NOTE
The initial mode is DX SEEK.
4 Press the g DN or f UP button to move
downward or upward one step respectively until
the desired station frequency is displayed.
NOTE
The ST indicator or STEREO indicator appears on the
display when a Stereo FM station is tuned in
You can also look at your manual here for any other ? you might have
http://akamaipix.crutchfield.com/Manuals/500/500CDM7874.PDF
2helpful
Program stations
Quoting from page 6 of the manual:
"Select the radio band and tune in a desired radio station you wish to store in the preset memory.
Press and hold, for at least 2 seconds, any one of the preset buttons (1 through 6) that you want to store the station on. The selected station is stored. The display shows the band, preset number and station frequency memorized. A total of 18 stations can be stored in the preset memory (6 stations for each band; FM1, FM2 and AM). If you store a station in a preset memory which already has a station, the current station will be cleared and replaced with the new station."
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=934dc6a1672f80b9d320c470df81f04d&q=Alpine+CDE-9842
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
