Televison & Video Logo
Posted on Jun 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SONY KP-65WS510 WONT TURN ON RED LIGHT BLINKS 4TIMES AND THEN OFF THEN 4 TIMES AND OFF ETC ETC
Joseph Hoffmann
Level 3:
President:
  • Master 1,756 Answers
  • Posted on Jun 08, 2011
Joseph Hoffmann
Master
Level 3:
President:
Answers
1756
Questions
Helped
409580
Points
4988
Hi, My guess is that you don't have adequate power for your flat panel. By all means do not use long extension cords. Try a different wall plug. You must have 120V ac to work. Read your manual that came with it. Good luck
I just changed the flyback transformer on my sony kp-65ws510 tv but still blinking 8 times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Possible Lamp Sensor Problem
Google the model number for six blinks for that is an error code---this set uses no lamp---it has 3 picture tubes
I have a sony 50". in the power button, a red
i have a sony 57". in the power button, a red blinking light blinks 11 times.
KDP57W5655
KP-65WS510 standby blinks 5 times then it shuts off
This is a indication of high voltage regulation cuircit problem. specifically the cb board. This is a board sony recomends sending to them to get fixed and adjusted
2helpful
2answers
The standby light just blinks when i try to turn it on and it wont turn on
Count the number of blinks of the standby light. It will bink a count, pause and do it again (Common counts are 2 -9) Give this count to a Sony service center and they can help you know what the issue is. (Probably the lamp)
2answers
Cant find reset button
Sony KP-65W510 tv does not have any reset button.
What is the issue with TV? I might help you.
4helpful
The tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
4helpful
Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Hello..i have a sony kp-61v80 tv year 2000
I have a sony codes for sony TVs that tell what is wrong by the blinks as soon as a can will ck it to see what it says.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
