SOURCE: hotpoint mistral plus 8596
IF the freexer is working fine then the evap thermistor is gone..
pretty cheap at around a tenner and easy to replace.. its located in the freezer section behind the panel near the top
remove all the freezer draws.. then remove the six screws to the back panel... remove the panel and its the yellow senor remove it and replace it exactly where it was plugged in and also attached to the evaporator.. the freezing section...
if both are not working then its the fan .....
at the back when the motor is
SOURCE: HOTPOINT MISTRAL plus 8596 fridge E2 code
Go to this site: http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewforum&f=35
Type "Mistral Thermistor" into the search and help will be availible. You have a very common problem which is an easy fix in most cases. Good luck.
SOURCE: why has my fridge stopped working but my freezer still works its Hotpoint mistral plus
the freezer has not gone into defrost there is a time clock inside or the defrost heaters are not working the fan will not blow the cold air into the fridge because its blocked up with ice the best thing to do is remove the food from your freezer (ie) put into another freever if you can unplug your fridge/freezer leave it off for 12 hrs thi will defrost and reset then turn it back on this will come back to life put your food back and keep a eye on it you may have to do this again once in a while because there is so much ice build up the heaters cant cope it only defrosts once or twice a day in a 24 hr period for only 1 hr it might be 2 half hrs in 24 hrs depending on the time clock you have they did change to digital towards the end of the minstral line
If it's working out if unit but not in, blade may be out of position and getting hung on shroud.
