Question about Refrigerators
Why has my fridge stopped working but my freezer still works its Hotpoint mistral plus
The high temperature lights is on permanantly but the fridge temp is on 0c degrees and the fridge is warm
Posted by AmyLeigh on
michael
    Sergeant:
  • 389 Answers
The freezer has not gone into defrost there is a time clock inside or the defrost heaters are not working the fan will not blow the cold air into the fridge because its blocked up with ice the best thing to do is remove the food from your freezer (ie) put into another freever if you can unplug your fridge/freezer leave it off for 12 hrs thi will defrost and reset then turn it back on this will come back to life put your food back and keep a eye on it you may have to do this again once in a while because there is so much ice build up the heaters cant cope it only defrosts once or twice a day in a 24 hr period for only 1 hr it might be 2 half hrs in 24 hrs depending on the time clock you have they did change to digital towards the end of the minstral line
Posted on Nov 26, 2011
  • 17,130 Answers
Possible that there is block on the air passage from the freezer fan which can be due to frost or failure of the fan.You need to check if there is free flow from the fan, also the setting of the fridge temperature.
Sounds like a faulty thermostat, although fast freeze usually bypasses the stat so should then get to temperature. If the compressor and condenser are getting very hot and all is clean, check there isn't a condenser fan stuck underneath that is seized. If not, may have had a bit of a refrigerant leak and sucked a bit of air into the system. Call an engineer
May 19, 2012 | Washing Machines
I just need instructions on how to set the temperature on my mistral fridge freezeer, please
please be aware that the temperature for the freezer compartment cannot be changed, this is pre set at the time of manufacture, only the fridge can be altered. The main reason for problems with zoned temperatures are to do with the compressor over heating. Unfortunately Hotpoint designed the compressor to switch itself off if the ambient (room) temperature exceeds a pre set figure. This in turn will obviously then lead to an increase in the temperatures of your fridge and freezer. I'm afraid the only solution to this problem is to relocate the whole unit to somewhere much cooler, especially during the hotter weather. This should in time sort the problem out. Also double check that the grill at the very bottom on the front, is not blocked up with dust etc.
Jul 01, 2011 | Hotpoint Refrigerators
Hotpoint Mistral Fridge Freezer, freezer working fine at -22 degrees, however, fridge has stopped working and is on +19 degrees. Had an E8 error message a few weeks ago which was quick fixed with a turn on...
Evaporator thermistor is on the radiator located at the back of the fridge. Older fridges had a big on aircooled along the entire back of the fridge whilst the newer ones have it under the fridge with a fan cooling it. 90% of the time the fan gives up causing this type of issue.
Jun 28, 2017 | Refrigerators
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
HOTPOINT MISTRAL plus 8596 fridge E2 code
Go to this site: http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewforum&f=35
Type "Mistral Thermistor" into the search and help will be availible. You have a very common problem which is an easy fix in most cases. Good luck.
Mar 13, 2010 | Hotpoint Refrigerators
Hotpoint Mistral Fridge freezer no Power Issue
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Dec 11, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Hi i have a hotpoint mistral plus fridge freezer, the freezer working fine however the fridge not getting cold, i have checked in back and the fan not working, have checked the fuse that is fine. 1) Does...
hi is this the frost free version ??? if it is which i think it is it could be a fault with temp module{frost free have electronic modules to control the system rather than a old fashioned bog standard thermostat inside the fridge} the fans should be controlled by the module in case of frost free models it could be the module which is playing up
Jul 23, 2009 | Refrigerators
I have a 10 year old hotpoint mistral plus frost free fridge freezer whic keeps coming up with EA as an error message in the display screen. We have turned the appliance on and off which sometimes solves...
thanks for the question yes it very well could i would pull fridge away from the wall and clean the condenser if dirty makes all the difference especially in that heat thanks the appliance doc
Sep 24, 2008 | Hotpoint Refrigerators
My hotpoint mistral fridge/freezer is freezing very will, but ther fridge is not cooling. What could be wrong?
Hi. I had the same problem (funnily just as my warranty had run out) hotpoint wanted about £90 plus parts for a call out. You need to replace the Yellow thermistor in the freezer compartment (quite easy with a cross screwdriver and thin fingers). I got mine from Uk White Goods for about £20 they give advice too. Solved it instantly. Thanks HOTPOINT, wont be spending £600 with you again. Good Luck.
Jun 20, 2008 | Refrigerators
Refrigerators Logo
368 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
