20 Most Recent Hotpoint HTS18JBPCC / HTS18JBPWW Top Freezer Refrigerator Questions & Answers
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Hotpoint... | Answered on Jun 07, 2012
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the advisable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Take care......
Hotpoint... | Answered on Aug 17, 2010
at the back there is a black house that will be blocked .defrost it look at the back right at the bottom and you will see the small house that will need unblocking
Hotpoint... | Answered 3 days ago
The drip tray should be firmly fixed to the top of the compressor unit - that gets quite warm during each cooling cycle. At the end of each cooling cycle the warming panel is switched on for a short time to melt the frost so the water drips into the tray shortly after the most heat is available to evaporate it and shortly after that the tray should be dry.
How can such a simple system fail?
Perhaps the tray is loose, perhaps the fridge is sited in a draught or perhaps there is a moist atmosphere in the fridge creating more frost and therefore too much water.
Hotpoint... | Answered on Jul 04, 2020
if compressor is running and no cooling is present --possible damage when defrosting causing loss of freon
Hotpoint... | Answered on Apr 16, 2020
no not outside temp unit its telling you the temperature you have unit set for is rising [[getting warm not cooling ]]
FREEZER /FRIDGE NOT COOLING:Optimumrefrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Checkurcold control thermostat,urthermistorsin both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as perurmodel ),urair flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) Onthermistorscheck for A close circuit and amount of ohms not just an Ohm reading. As perurmodel. Most shouldatleastshow 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poorcooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check thedefrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engageurdefrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providingurterminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Placeurmeter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Takeurmeter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Nowur1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u knowurtimer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor,relay and or capacitoris overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To checkurcompressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somelocated next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes tourstart winding, 1 goes tourrun winding and the center goes tourground.
Placeurmeter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prongagin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total ofurtwo separate test. 9 ohms, if they matchurok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short inurcompressor. It should show infinity
TO REPLACE RELAY AND CAPACITOR WITH A HARDSTART KIT YOU CAN USE
A3 in 1 start kit for compressors sizes 1/4 through 1/3 HP. And a 5 in 1 for higher H.P. (BE SURE TO MATCH WITH UR COMPRESSOR MODEL NUMBER AND TYPE) Thekit includes relay, capacitor, andoverload device, pre-wired. Thekit will replace all 3 electrical components on capillary refrigeration systems. For newer systems with a run capacitor use?proper kit. For smaller horsepower compressors useTJ90RCO810.
The wire set up is as follows the red wire goes to the right side of compressor prong, the white wire to the left side prong, the black wire to the center prong, and the 2 other black wires go to the power and the ground connection
Lastly you should also checkurTHERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
1-3 TEMPERATURE CONTROL
As the food in the fridge gets colder, it gives off less heat, and the air inside the fridge will remain colder. A thermostat called aCOLD CONTROLwill cycle the cooling system on and off to keep the temperature inside your fridge within a certain range. You can adjust that range using one of the dials within your fridge.
On most fridges, all the cold air for both the food compartment and the freezer compartment is produced in one evaporator. Since the freezer is so much colder than the food compartment, most of the cold air that is produced circulates to the freezer compartment. Only a small amount is needed in the food compartment to keep it down to the proper temperature. This amount is adjusted by a smallAIR DOORin the duct between the evaporator and the food compartment. The control for this air door is the other of the two dials within your fridge.
If you hear your compressor "short-cycling" (starting and stopping at short intervals) try jumping across the two leads of the cold controlthermostat ( in the fridge compartment)with an alligator jumper.You can also check both for live voltage current and ohms-If there is a greenthirdlead, ignore it for this test; it is the ground wire. If the fridge starts running constantly, the cold control is bad. Replace it.
To test or change the coldcontrol, firstPull the knob off it and remove any plastic cover plateor housing from it.
You will see two wires leading to it. There will also be a thick, stiffCAPILLARY TUBEattached. The capillary tube is the liquid-filled temperature-sensing element of the cold control, and operates in the same manner as a thermometer
The air damper, baffle or diffuser is the device that balances the air flow from the evaporator fan housing. This normally is a mechanically controlled baffle or flapper that controls the amount of cold air entering the fresh food compartment. If the baffle is damaged or the linkage to the control knob is damaged, then you may not have enough cold air entering the fresh food compartment resulting in higher than normal temperatures. This baffle or damper will be located where the cold air enters the fresh food compartment.
Read more:
http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
http://www.appliancerepair.net/refrigerator-repair-1.html
https://www.youtube.com/watch?v=KqXN-ZCuptk THIRMISTOR CHECK
damper assembly whirlpool-control-damper-12571701-ap4013860_01_l-undefined-undefined-5.jpg
Hotpoint... | Answered on Mar 29, 2020
Check the freezer: If your fridge does not have an auto-defrost function then excessive ice-build up in the freezer can cause the beeping alarm. If you see a lot of ice build-up in the icebox or freezer, switch off the fridge and let the ice thaw. Once the fridge is thawed, the beeping should stop.
https://www.appliance-insurance.co.uk/appliance-insurance-articles/6-causes-beeping-fridge/
If the fridge is overcooling it could be the thermostat. If the defrost panel is permanently switched on, overcooling might not be noticed but the condenser will become quite hot.
If running continuously, there is no overcooling and the condenser remains cool, either the compressor is defective or the refrigerant has leaked away.
Hotpoint... | Answered on Dec 11, 2019
hi
sounds like the freezer part has an ice blockage the clicking may well be the fan chipping at ice and no air flow will mean the freezer is partialy working yey not allowing cold air to fridge
if this is the case to proove point give unit a good defrost for as long as possible then turn unit back on
if this works it will require a service engineer to check the defrost cycle of the unit is no longer failing
good luck
Hotpoint... | Answered on Sep 01, 2019
Turn the power off to the refrigerator and manually defrost the freezer until the freezer bis no longer cold and then replug the power cord
.APPLIANCE 911
Hotpoint... | Answered on Jun 22, 2019
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:SIY_RFFRIDGETEMP
What should a Hotpoint fridge temperature be?
Your Hotpoint fridge is designed to operate at a temperature ranging from 0.5 degrees in the coldest part up to 5 degrees inthe warmest part.
As warm air rises and cold air falls it is safe to say that the best way to store your food is to place it in the most appropriate shelf compartment, as shown in the diagram below.
  • Zone A - Cool Dairy Products, Cheese, Butter, Margarine, Low Fat Spreads, Cooking Fats/Lards, Preserves, Jams, Curs, Marmalade, Salad Dressing or Sauces
  • Zone B - Colder General Food Storage
  • Zone C - Coldest Meat, fish & poultry, Pre-cooked/chilled food
  • Zone D - Salad Bin, Vegetables, Fruit and Salad Items
Hotpoint... | Answered on Apr 27, 2019
Does the fridge still do it's job? If it does then perhaps the fan only comes on when needed.
Hotpoint... | Answered on Apr 09, 2019
Hotpoint HTS18JBPCC / HTS18JBPWW Top Freezer Refrigerator Logo
2 questions posted
Top Hotpoint Refrigerators Experts
jdthefixer
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Refrigerators
Most Popular Question
freezer frost in
  • Refrigerators
