This has actually happened to other people? When this happened to me I was shocked, I've never in all my years have ever dealt with something like this. I had tried to fix it for a good two weeks. I had to break down and call in some <a rel='nofollow' href="http://www.doorsystems.com">door systems in Chicago</a>, to help out. I hate fixing doors. I have the worst luck with them.
SOURCE: Stuck Microwave door
The button assembly or the arm thats attached to the push button is broken. With the unit unplugged. Carfully take off the screws from the sides and around the back of the unit around the outside of the cover. Now once apart, DO NOT TOUCH any electrical parts. Look at the mechanism and see if you can see why the buttons not activating an arm to trigger the door latch. If you think you see why, Go to http://www.repairclinic.com and enter your model #.. Answer the questions and then a bunch of parts will come up. If they dont then get the tele # from there and call them. Depending on how old the oven is, you may want to consider a newer oven??. Good luck
SOURCE: the door sticks on my microwave oven
Usually this is due to loosened mounts inside the oven. The mounts hold the door switches and grab the door hooks when it the door is closed. The solution is to realign and tighten the mount screws inside. It's less liekly, but it could be a weak or worn door open lever inside. I only advise people to work on a microwave if they're fully informed and aware of the deadly hazards and necessary precautions.
In most cases this is due to a broken door opening lever or loose or broken door latch / hook parts. They can only be accessed and examined if the cover is removed from the microwave. In many over the range models, you can access the door parts by removing the control panel assembly. Sometimes you may be able to get it open by pushing up gently on the bottom of the door while pushing the button, in case you need to empty it.
SOURCE: Maytag Microwave model#MMV5186AA
Typically, no heating of food, indicates a bad Magnetron (tube) or associated components. The oven can be repaired. Magnetrons are not hard to replace and can be ordered online through MCM electronics www.mcmelectronics .
However, due to the dangers of high-voltage within the unit, I would recommend taking the unit to a repair center.
Look in the manual to see what the warranty says. See if there is any information regarding the magnetron or parts. You may be able to get it repaired for free parts, less labor.
Please let me know if I can be of further assistance to you.
Good Luck,
- Jim
SOURCE: Sharp microwave oven model r-1440 runs, but doesn't heat food
Assuming your inside light and
turntable come on when you try to microwave, with the symptoms you have,
I would most strongly suspect a bad magnetron or a loose and possibly
corroded connection on the magnetron's terminal.
If
you or someone you know decide to look into it, we have critical safety
information and disassembly information at our site, and our link is at
our listing here on FixYa.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it'sprobably okay)
http://www.gallawa.com/microtech/mag_test.html
The best place to order
parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
