Brother IntelliFAX 1270E Plain Paper Fax Logo
Posted on Mar 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1270 e MAKING a shrill sound and screen says parameter init. Had to unplug to make sound stop. Still says parameter init when plugged back in
Anonymous
Level 2:
Novelist:
  • Expert 129 Answers
  • Posted on Mar 29, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
129
Questions
0
Helped
41724
Points
378
It may need to be reset.
Please try to unplug it. press & hold the menu/function key while plugging it back in. When lights are blinking release it then press 91. and then display will show parameter init then change to maintenance. Press 99. The display should show date & time.
Hope this helps.
1helpful
Factory reset
Chapter15 The Init Button
The Init button is used for maintenance: Simultaneously press Init button and turn on (by plugging
in the power adaptor) the Server until USB1 LED indicator simultaneously blinks. After that, the
Server will do the following tasks:
A. Perform a Factory Default of the MFP server, which will restore most of the parameters and
settings to factory default values,
B. Perform a TFTP server. You can upgrade new firmware using any TFTP client tool.
Note: After performing the tasks mentioned above, you have to unplug the power adaptor and then
plug in the power adaptor to restart the Server.
HMPS1U Print Server for Multifunction Printers
Error 76
try this- press the "menu/set" button, then " *2864 " . the *2864 you have to enter within a 2 second window, so you may have to try this more than once. when you hear a long beep, you got it. press "91". you should see "parameter init" on screen. wait for that message to disappear. unplug machine at this point, wait 5 seconds and plug back in. if it comes up with that error again, then you truly have a problem with your fusing unit and will have to have repaired. sometimes though, this error can be caused just by a power outage or fluctuation. if thats the case it should come back up to normal after you successfully do this procedure.
good luck
razors
2helpful
How do i reboot my sharp dolby digital tv?
unplug set press and hold down valome and channel down and hold them while pluging in set will come on with k on screen us your remote and arrow right then look for fact init and any othe reset and turn them on arrow back up to fact init and hit enter let set recyle and unplug and re plug in 5 seconds the set is noe in virgin mode
2helpful
Factory reset mpc2000xl
The procedure is as follows: go to the INIT Screen. Hold down SHIFT and press OTHER (8 on the numeric pad) to display the OTHER mode screen and press INIT [F2] to display the INIT screen. This will initialize ALL PARAMETERS.
Pressing DO IT will initialize. Pressing DO IT [F6] erases the parameter data from the MPC2000XL memory and initializes them to their default parameters.
If you need a manual for your unit, you may find it here:
http://www.audiorents.com/library/userManuals/mpc2000x.pdf
Hope this helps. Take care, and thanks for using FixYa!
Apr 05, 2009 • Music
7helpful
The tv quit responding to the remote
On this unit if you do a fact reset it should fix this problem steps as follows. PS you might need 2 people
1- unplug power cord from back of TV
2- on the key pad on the tv hold the input and vol dowm buttons
3- while holding the buttons plug the tv in, keep holding the buttons until the screen comes up.
4- once the screen is up there should be a white K in a blue or green box.
5- next, on the key pad on the tv press the channel and vol down buttons once.
6- a menu should pop up
7- using the sharp remote,locate the directional pad
8- press the down button once should bring you to a 2nd page
9- top should state FACT INIT press the right arrow once to turn on, next a series of back slashes come up.
10- screen goes green and says INIT Successful
11- unplug power cord from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
2answers
Panafax dx-800
Press Function, then 7
Press 4, then Copy/Set
(it should ask for a fax parameter, the one for the key sound is 010)
Enter "010", then Copy/Set
Set the parameter to "1" for Off, then press Copy/Set
Press Stop to exit back to the default screen
No picture
Bad IHVT ( flyback transformer)--need complete service
number off back for part #-----------Let me know...T.
Norman Weimar
Norman Weimar
k24674
