Cameras Logo
Posted on Feb 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 84 year old mother has a 7022 how does she update date and time and also how do you remove date and time from appearing on the photo print thanks
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Vivitar Master 102,366 Answers
  • Posted on Feb 20, 2011
Vivitar Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444301
Points
622693
In the shooting mode, press SET to bring up the menus. Use left/right to select the Date/Time menu. Use up/down to select an option and press SET.
The three options are On and Off for the timestamp appearing on the photos and Date Setup for changing the date/time.
How do you date stamp panasonic lumix photo
The date and time (and a lot more) are stored with every photo in its EXIF metadata. This data stays with the photo unless explicitly removed. Just about any photo viewing/editing program should be able to show you this data. If you want to print the date, please refer to the documentation for whatever program you're using. Depending on the program and printer, you may print the date on the image, in the margins, or on the back.
Cannot get date to print on .jpeg images when downloaded
The date and time (and a lot more) are stored with every photo in its EXIF metadata. If you want the date printed on your photos then please refer to the documentation for whatever program you're using to print. Depending on the program and printer you may have the option of printing the date on the image, in the margins, or on the back.
How do I change the date and time on a vivcam8225
Hello and welcome to FixYa!
This following steps allows you to set the system time which will be displayed on the photos.
  • Press the Up or Down buttons to select the Date option in the Setup menu.
  • Press the OK MENU button.
  • Press the Up or Down buttons to select a Date option from the menu that appears
On selecting "On" the date will appear on the photo once it is taken.
On selecting "Off" no date will appear on the photo.
On selecting "Set Date" the Set Date settings screen will appear. You will be able to change the date settings that will appear on the photo once it is taken.
To Set the date:
  • Press the Up or Down button to enter the Set Date option.
  • Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, Second and Date Format type.
  • Press the Up or Down button to set the Date and Time digits.
  • Select the first option of the Date format and press the Up or Down button to set the date format that appears on the top line: YY MM DD; DD MM YY; MM DD YY.
  • Press the OK MENU button to confirm, save the changes and exit.
You have done it.
I hope this solution helps you
If you have any more query or issue regarding your problem do inform me.
Thank you for using FixYa!
Have found where I can set date/time on my Vivitar CAM6300 Digital Camera but stamp doesn't appear on actual digital photo. How can I set the date/time to appear on the final image?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
1helpful
I AM TRYING TO SET THE DATE & TIME TO APPEAR ON MY PHOTOS ON MY CANON REBEL T2I
theres no date a time stamp on the photo itself with DSLRs but the meta data is kept on file in the photo so it has recorderd the time and date. depending on what photo printing software your using you can bring up the time and date back on the photo. I have canon photo printer and using the bundled software easy photo print, it allows me to print time and date of the photo. or if you use adobe lightroom you can get the time and date back on the photo. the time and date stamp is more of a compact camera rather than DSLR.
YTD total don't print on paychecks Aatrix Top Pay
When it asks the date of the check, you must us 2010 and not just 10 for the year. Then it quits asking, "you are about to print checks for another year, are you sure you want to do this?" I had to delete all the old check to date, and then re-enter them with the four digit year of 2010. YTD then updates OK.
1helpful
3answers
How do i remove the time and date at bottom right corner of picture.
Manual can be downloaded free from here ....
http://safemanuals.com/annexe_POWERSHOT%2020A550%2020CAMERA%2020USER%2020GUIDE%2020ADVANCED%2020_CANON_POWERSHOT%20A550-_E.htm
Basically the date stamp can be turned on / off as an option on the RECORD menu. Page 33 of the manual explains it (with pictures).
Note that if the option is turned on, it states that the date / time is permanently embedded in the picture.
Hope this helps
1helpful
2answers
Need some1 2 explaint to me how I get the d&t printed on the photo for a canon powershot 1S camera please
you can Print the date and time to the picture when you take the print of it. It does not embed the date and time data into the image itself.
From the manual please read this
" Setting the date and time settings does not cause the date/time stamp to appear on images"
To print with date
This option will be available only for printing on card size paper
In the print order screen, select [Style] and press the SET button
You will get 3 options to set
1) Image
a) Standard b) multiple
2) Borders
a) Borderless b) Bordered
3) Date
a) On ( Adds the date to the print )
b) Off ( Prints without the date )
Select Date option as On and the date will be printed on the picture.
still you are having any doubts, please refer to user manual and Direct Print User Guide
which i am giving as links here.
user manual
Direct print user guide
Hope this helps you
Thank you
2answers
Putting a date on the pics i take with a canon powershot
Hi Steve, thanks for coming to FixYa.
First, for your model of camera, you do know that you can only Print the date and time the pic was taken on the photo right? It does not embed the date and time data into the image, like some cameras do.
Here is a direct quote from the manual if you want to check my information. You will find it on page 21. "Setting the date and time settings does not cause the date/time stamp to appear on the images."
This may/maynot be what you wanted, either way let me know with a comment. I can describe how to set the date and time in the camera's setup menu for you if you want, and/or I can tell you how to make sure you print the date and time on your photos. Otherwise, have fun with your camera and please rate my solution a fixya.
Rob
Date still doesn`t appear on the photo in my computer
You need to take the photos with the date option on, and it becomes a permanent part of the photo. You cant turn the option on and off dynamically. Use the cameras menu to turn the date on and you should be OK from here on in! Thanks!!!
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
