20 Most Recent Canon EOS 550D Rebel T2i Digital Camera Questions & Answers
How to replace lateral rubber cap in canon 550d
Thank you for sharing superb information's. Your web-site is so cool cctv camera installation services best cctv installation in Hyderabad
9/9/2021 12:51:24 PM • Canon EOS 550D... • Answered on Sep 09, 2021
I have a Canon Rebel t2i. The LCD screen does not display any images including menu items. How can I get it to work? Details below...
This appears to be a deeper problem than can be fixed with advice on here. I suggest you take it for a professional repair. Check the repair estimate with the value of the camera.
12/2/2016 7:29:37 PM • Canon EOS 550D... • Answered on Dec 02, 2016
2answers
Video taping stops after a few second from
Sounds like your card can't keep up. If it's an SD/SDHC card, make sure it's a class 6 or better.
5/11/2016 7:35:08 PM • Canon EOS 550D... • Answered on May 11, 2016
2answers
Camera turns off when I shoot a movie Canon EOS 550D Rebel T2i Digital Camera
This is also a guessing game. Your experience in the use of the camera? If you are new, I suspect the settings may have something to do. One simple method to prevent your camera from switching off (timed out) is to do some dummy manipulation on any of the buttons on the camera while shooting. eg. press the menu button or turn the wheel every few seconds to keep the camera awake. Make sure the button manipulation does not actually affect the recording of the movie. OR re-set the camera settings to its defaults - (factory settings)
5/11/2016 7:34:24 PM • Canon EOS 550D... • Answered on May 11, 2016
Error code 50
According to the Canon website for error codes http://www.canon.co.uk/Support/Cons....aspx?faqtcmuri=tcm:14-754472&page=1&type=faq it seems like either a mechanical or electrical fault or maybe both. You could try taking both the batteries out (main and clock/memory) and leaving it a while, and also try cleaning the contacts of the camera and lens and try again. It doesn't look too good for you though, maybe it needs a trip to the service centre.
5/11/2016 7:29:58 PM • Canon EOS 550D... • Answered on May 11, 2016
Auto focus not working
Have you checked the lens AF/MF button? Perhaps your lens is in Manual Focus mode? auto-focus-not-working-mscpfsinexfgkvjnkzk5efuu-2-0.png
5/11/2016 7:28:11 PM • Canon EOS 550D... • Answered on May 11, 2016
Why are all my photos are coming out blue
One possible cause is the settings -White Balance. Make sure the white-balance is set to auto and check if any changes to your subject and photo.
11/2/2015 4:34:58 AM • Canon EOS 550D... • Answered on Nov 02, 2015
Error 80 on my canon 550d
Have a look here at the Canon Error codes http://www.canon.co.uk/support/consumer_products/product_ranges/cameras/eos/error_codes/
8/29/2015 8:10:51 PM • Canon EOS 550D... • Answered on Aug 29, 2015
My canon eos 550d shows error 80
ERR 80: SHUTTER DESCRIPTION: This error occurs in the following conditions. When the CAMERA self-check system detects that the shutter has not been fully charged (ready to shoot). When the CAMERA self-check system detects that the shutter operation sequence has not been completed correctly. When the built-in flash cannot be recharged after the E-TTL preflash but before the main exposure. REMEDIAL MEASURE: Try clearing the error by turning the main power switch OFF and then back ON.
12/28/2014 9:33:26 PM • Canon EOS 550D... • Answered on Dec 28, 2014
Extension tube stuck
Take it to the repair shop and get a proper fix done.
12/28/2014 9:24:00 PM • Canon EOS 550D... • Answered on Dec 28, 2014
T2i SD card say it's full but the card is empty
Try formatting the SD card from the camera. You can find this option in the menu.
12/27/2014 10:03:29 PM • Canon EOS 550D... • Answered on Dec 27, 2014
Black screen pictures
Take off the lens cap.
12/27/2014 10:01:16 PM • Canon EOS 550D... • Answered on Dec 27, 2014
52mm lens stuck on body,,how do you unstick it?
Normally, these lenses do not 'unscrew'. When you push the red button, it releases the lens catch and then you rotate the lens a short ways counterclockwise, then gently pull forward on the lens while holding the body of the camera and the two units separate. It is possible you have gotten some dirt into the lens latching mechanism. Try returning the lens to the locked position, press the red button, rotate the lens to where it stops and then returning the lens to the locked position and repeat several times if the lens does not lift out when you hit the movement stop. This may allow you to get past the dirt. Otherwise, take it to a camera shop, particularly if the camera is still under Canon warranty.
12/4/2014 2:08:15 AM • Canon EOS 550D... • Answered on Dec 04, 2014
How can I put my Cannon $40D camera to IR mode to use a wireless remote control
The IR mode is the timer mode.. On top the camera press the AF button while rotating the selection dial. You see the icon on top the camera switch from a single square, to several stacked squares, then to a clock with a been. That's the IR mode. if you press the shutter button you active the 10 second timer, air you have a IR trigger the camera will receive in in this mode.
11/30/2014 6:13:04 AM • Canon EOS 550D... • Answered on Nov 30, 2014
I have a canon 550D. All of a sudden I started
Try using Canon's software. Digital Photo Professional that came with your camera. If it works here then your problem is NOT your camera but your computer, usually software.
11/30/2014 6:04:54 AM • Canon EOS 550D... • Answered on Nov 30, 2014
How to remove error- card protected in canon Eos d rebel t 2i
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
10/7/2014 11:33:12 PM • Canon EOS 550D... • Answered on Oct 07, 2014
I cannot download photos from my EOS 550D to my
try this one in reverse first open utility and then plug into the pc.
9/16/2014 7:59:30 PM • Canon EOS 550D... • Answered on Sep 16, 2014
How do I get my canon camera to work
Add some details on your questions for anyone to respond to your question.
9/5/2014 1:06:45 AM • Canon EOS 550D... • Answered on Sep 05, 2014
2answers
Why does my camera say "No card in camera" what's going on?
All the Canon's are having this issue. They should do a massive recall. I'm sold mine on craigslist. Canon will repair it for $220. The Canon t2i's are no longer even worth that. I think they've made more off the "no card in camera error" than selling the T2i's the first time.
8/22/2014 6:25:56 PM • Canon EOS 550D... • Answered on Aug 22, 2014
Canon EOS 550D Rebel T2i Digital Camera Logo
169 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Eos Canon
  • Eos Canon
Most Popular Question
camera say no card in camera going
  • Cameras
