20 Most Recent Vivitar ViviCam 6300 Digital Camera Questions & Answers
My vivitar will not come on a blue msdc screen and
I just called the help desk. MSDC and a blinking red light means that it is charging. It takes 6 hours to charge and you are not to take disconnect it from the USB until it is fully charged. Once it is charged the blinking light will turn green.... not sure whether it will still be blinking or not. This is what the lady on the phone told me so I haven't been able to try it out yet, but I will update if I call again.
12/29/2012 1:11:09 AM • Vivitar ViviCam... • Answered on Dec 29, 2012
Vivitar6300download
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
9/2/2012 7:04:15 PM • Vivitar ViviCam... • Answered on Sep 02, 2012
My camera is saying card locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
8/9/2012 9:52:31 PM • Vivitar ViviCam... • Answered on Aug 09, 2012
Len will not come out when camera is turned on
Try the procedures in this tip.
8/9/2012 9:52:26 PM • Vivitar ViviCam... • Answered on Aug 09, 2012
Have found where I can
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
8/9/2012 9:49:23 PM • Vivitar ViviCam... • Answered on Aug 09, 2012
Cant find Vivicam 6300 driver - Vista
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
8/9/2012 9:49:17 PM • Vivitar ViviCam... • Answered on Aug 09, 2012
How do I put a
8/9/2012 9:46:37 PM • Vivitar ViviCam... • Answered on Aug 09, 2012
Downloading pictures
8/9/2012 9:46:20 PM • Vivitar ViviCam... • Answered on Aug 09, 2012
When i display still photo . It hss horisental
You have the circuit problem inside camera. Please get it repaired at dealer then.
Regards, Jay
3/1/2011 4:26:04 PM • Vivitar ViviCam... • Answered on Mar 01, 2011
I cant install a driver
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
12/26/2010 7:50:48 AM • Vivitar ViviCam... • Answered on Dec 26, 2010
The lens won't come out nor will it go in. What do I do?
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/30/2010 9:30:42 AM • Vivitar ViviCam... • Answered on Sep 30, 2010
I need software download to make my Vivitar digial
You don't need the drivers...just use a card reader to download your pics.
11/27/2009 10:03:36 PM • Vivitar ViviCam... • Answered on Nov 27, 2009
Need driver for Windows XP for compatability
like go to best buy and buy one
11/27/2009 6:47:26 PM • Vivitar ViviCam... • Answered on Nov 27, 2009
Vivitar manual & installation disc for 6308 6 megapixel
Most probably find a Vivitar Vivicam 6300 manual & software here. Just send them a search request. Search service is not for free, but worthy.
5/29/2009 9:01:20 AM • Vivitar ViviCam... • Answered on May 29, 2009
Removing the date
+Oh dear, I haven't run into this situation before. Possibly you could go out the makers web site, and request some assitance from their tech section.
8/5/2008 7:12:12 PM • Vivitar ViviCam... • Answered on Aug 05, 2008
ViviCamera 6300
You should be able to do this in your menu.
8/5/2008 1:23:08 PM • Vivitar ViviCam... • Answered on Aug 05, 2008
2answers
How to retrieve deleted videos fro VIVITAR DVR508NHD video camera.
You can certainly recover the videos from it. Just connect your camera to your PC and make use of the app shown here in this tutorial...
2/26/2021 5:37:07 AM • Vivitar ViviCam... • Answered on Feb 26, 2021
Vivitar ViviCam 6300 Digital Camera Logo
22 questions posted
Top Vivitar Cameras Experts
David Shaub
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
camera saying card locked
  • Cameras
