Maytag 24 in. MDBH955AW Built-in Dishwasher Logo
Posted on Feb 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The auto wash/start/delay start touch controls will not respond...all other control panel area's are working, but I can not get it to start.
Sam
Level 3:
  • Maytag Master 3,247 Answers
  • Posted on Feb 11, 2011
Sam
Maytag Master
Level 3:
Answers
3247
Questions
0
Helped
1306403
Points
10378
It is possible the button contact has moisture or some contaminent. Best to open the control panel and check under the button. Take photos as you go along to make sure it all fits together. You can check the part locations in this diagram.
My windows on my 2005 F150 FX4 will only operate from the drivers door switches. New switch panel on the drivers door.
What's FX4 ? How many door's ? Do the other door switches have battery power ? Can you test this with a volt meter ?
Principles of Operation
The left front window switch may be used to raise or lower all windows, or each individual side window may be controlled by the control switch located on each door panel.
The instrument control module (ICM) controls power to the power window system by activating or deactivating the delayed accessory relay.
The one-touch down feature will completely lower the driver side window when the master control is fully depressed, then released. The one-touch down feature is integrated into the LF window control switch.
There are 2 modes of LF window down operation: manual mode and auto mode. The manual mode is selected by pressing the LF window control switch to the 1st (DOWN) position. In manual mode, the window will move downward only while the switch is depressed. When the LF window control switch is pressed to the 2nd DOWN position, it enters auto mode and the window will open completely with a momentary press of the switch.
When the one-touch down feature has been activated, it will stay on until one of the following conditions is met:
  • The LF window control switch is pushed to the UP position.
  • The LF window control switch is released (OFF position) and then moved to the DOWN position (1st detent) or ONE-TOUCH DOWN (OTD) position (2nd detent).
  • 7 seconds have elapsed since OTD was initiated.
Window operation is enabled whenever the delayed accessory is active and the LF window control switch is pressed to the UP or DOWN position. The switch provides delayed accessory power to one side of the motor and ground to the other side. The one-touch down feature is not active when the LF window control switch is in the UP position.
Passenger windows may be raised or lowered using the LF window control switch or the appropriate passenger window control switch. Passenger window control switches receive power when the delayed accessory relay is active and the LF remote lock-out switch is in the UNLOCK position. When in the LOCK-OUT position, the passenger windows are deactivated.
The delayed accessory relay provides power for the operation of the power windows and the power roof opening panel. The delayed accessory relay is active whenever the ignition switch is in the RUN or the ACC position, or when the ignition switch is changed from RUN or ACC to the OFF/LOCK position and the LF and RF doors are closed.
The ICM will deactivate the delayed accessory feature when:
  • The LF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • The RF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • 10 minutes have elapsed since the ignition switch was changed from ACC or RUN to the OFF/LOCK position.
  • Symptom Chart Condition Possible Sources Action
    • All power windows are inoperative
    • Fuse(s).
    • Circuitry.
    • Instrument cluster module (ICM).
    • Accessory delay relay.
    • Driver window control switch.
    • Go To Pinpoint Test A .
Managemylife com sears
New problem or old problem? Has it ever worked? First check the main control component and make sure all wires are plugged in.
DD605i touch panel no longer responds. Service guy came and advised on a new board. My wife noticed that he was able to change the wash modes using the from rectangular panel with the power, lock and
What he did from the front panel was put it into a service diagnostic mode. This will not help you as it does not let you run a normal wash cycle from this mode. Most likely the controls are not responding because the control board is not being held up tightly against the underside of the panel. If there is a gap, the buttons will not respond. You may be able to wedge something under the mounting tabs to force it up tighter. You have to take the front of the door off to do this.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
1helpful
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
3helpful
A red padlock symbol is showing on the panel of my WCVH6800 front load washer. I can't change any of the wash settings. How do I fix this?
Here's what the Padlock represents:
Lock Function
You can lock the controls to prevent any selections from being made. Or you can lock the controls after you have started a cycle. children cannot accidentally start the washer by touching pads with this option selected.
To lock the washer, press and hold the DELAY START button for 3 seconds (on some models use SIGNAL button). To unlock the washer controls, press and hold the DELAY START button for 3 seconds. The control lock icon on the display will light up when it is on.
NOTE: The POWER button can still be used when the machine is locked.
Maytag Bravo, the control panel does not respond every time, and the wheel to choose the wash load is out of control. the delay timer you just have to keep pushing and maybe it will finally set, i use the...
the washer control knob needs to be replaced but dont replace the entire control the main timer cog can be replaced on its own at around 80% less money than a whole new controler
5helpful
Control buttons don't work, Help.
donnson, sounds more like the touch panel shorted or stuck keypads. You can remove the touch panel ribbon from the control board and try to clean it with an eraser. You will need to remove the torx screws and remove the inside panel. See if it comes back to life. Behind the toe-panel on the bottom, there should be a tech sheet showing how to check the key pad. The key pad and control board are warranteed for 5 years on this model, parts only. Catriver..post back.
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
