20 Most Recent Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Questions & Answers
donnson, sounds more like the touch panel shorted or stuck keypads. You can remove the touch panel ribbon from the control board and try to clean it with an eraser. You will need to remove the torx screws and remove the inside panel. See if it comes back to life. Behind the toe-panel on the bottom, there should be a tech sheet showing how to check the key pad. The key pad and control board are warranteed for 5 years on this model, parts only. Catriver..post back.
Maytag 24 in.... | Answered on Jul 17, 2011
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Maytag 24 in.... | Answered on Mar 27, 2011
heatman101
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Maytag 24 in.... | Answered on Feb 20, 2011
Check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Maytag 24 in.... | Answered on Feb 19, 2011
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Maytag 24 in.... | Answered on Oct 27, 2010
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Maytag 24 in.... | Answered on Oct 01, 2010
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Maytag 24 in.... | Answered on Sep 30, 2010
Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
76 questions posted
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dishwashers
  • Maytag Dishwashers
Most Popular Question
grit inside glasses dishes
  • Dishwashers
