My LUMIX DMC-TZ3 isnot able to transfer pictures to my laptop which has Windows Vista as the O.S.Pictures can be transferred by photo impression application only.EArlier it was O.K.when my PC had Windows XP.Is the camera or the CD supplied incompatible with Windows Vista/
Photo transfer from the camera to a computer is usually done with a USB cable. For detailed instructions on how to transfer the pictures, check out the user manual: Panasonic DMC FX8 manual
You have to connect to a pc, transfer the pictures to the computer, then you can transfer them from the computer to the memory card file on the camera.
If you mean, how do you see pictures stored on the internal memory, you have to take out the SD card, then transfer the internal pictures to the computer via the USB cable. You can erase the internal memory from the computer, if you want.
there might not be a way of transferring picture within the camera. However the SD card _should_ have resolved the memory full issue. Plug the camera into a computer with its USB cable. Transfer the pictures to the computer and delete them off the internal memory. Assure that your SD memory card is functional by trying it in another camera or in the slot on a computer.
I reinstalled the software that came with the camera. I restarted the computer and this time the pictures were transferred from the camera onto the computer.
Do you have a USB card reader? Just take the card from the camera, pop into the reader, and you can transfer your photos.
No drivers required unless using Windows 98 or earlier.
Also, the model is wrong, do you mean TZ5? You should be able download software for the camera from www.panasonic.com
Hello, It might be an idea to check whether your "white balance" is not set to "fluorescent light" or "custom white balance". "Auto" is the safest option here. Incorrect white balance would cause blue/yellow cast on the picture. Otherwise the problem might be more severe (i.e. sensor failure-not common in TZ3 though). If you're still getting blue cast with white balance set to auto, you can try to set "custom white balance" with white sheet of paper (refer to the manual for details) - this will override auto white balance. Good luck! Raf
