Run the service diagnostic mode to determine which button is stuck. Start by pressing and holding the Select and Cancel buttons simultaneously for 6 seconds to reset the control.
Rotate the cycle selector knob 5 turns counterclockwise to the second position from the bottom immediately after the buzzer sounds.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control enters the test mode and the buzzer wi have a frigidaire affinity dryer that will dry - jahn27_114.jpgmes with all of the LEDs flashing.
Rotate the cycle selector knob 4 turns clockwise to the second position from the top and the dryeri have a frigidaire affinity dryer that will dry - jahn27_115.jpgth the heating element off. The buttons can now be tested to determine which is stuck.
Press each button and all corresponding LEDs should light. If the LEDs corresponding to a certain button lights up wi have a frigidaire affinity dryer that will dry - jahn27_122.jpgg the button or if i have a frigidaire affinity dryer that will dry - jahn27_116.jpgt light up when thei have a frigidaire affinity dryer that will dry - jahn27_119.jpgssed, that button mi have a frigidaire affinity dryer that will dry - jahn27_118.jpgr not making any coi have a frigidaire affinity dryer that will dry - jahn27_120.jpgssed.
Replace the control board if the stuck button cannot be unstuck or if there's no button that's apparently stuck but the fault code persists. Let us know if you need further advice.
