Bjr y at il un freeware qui me permet de calibrer la batterie de mon acer aspire 5630 aspire merci [email protected]
Hi, Your battery needs to be calibrated, what you will need to do is charge the battery fully or until it can not charge more, drain the battery completely then recharge to full, doing so while letting your computer recognise and mark the full point and the empty point... the process depends on the version of windows you have and also if you have a bundled tool or a program that does this for you, search your laptop installed programs or check in your power options. vista is the only operating system I am aware of that does not have a built in tool, others should have it, just follow the tool instructions and you should be all set, if you can not find the tool or have vista let me know... Best of Luck
i have windows 7 premium 64 bit , where can i look for tools ?
Ok, when you start the laptop go into the bios and see if there is any power options (you may also find battery calibration tool there too but if not...) turn any power managemnet option off, restart the laptop and wait until it fully loads. go into the control panal and select power, also turn any power management option off or disable hibernation at the critical battery... now wait until the battery is fully charged or can not take more then unplug the ac power, you may continue working on the computer or just let it drain the battery until it shuts off by itself, make sure you save your work because if it shuts off any unsaved data will be deleted, try turning the computer on, it should shuts down again after few seconds. now plug the ac in and let the laptop charge overnight or at least 10 hours, then turn it on and notice the charge %... then unplug the power and let it drain from the battery again until it shuts off... repeating this 2-3 times should do the trick... Good Luck.
the laptop charging didnt proceed more then 91 % even if it is plugged for several hours and it keep on charging , so wat to do nw ?
