20 Most Recent Acer Aspire 5241 5251 5332 5334 5338 5516 5517 5532 5541 5542 5551 5551G 5553 5553G ... (30034027032) AC Adapter Questions & Answers
Acer 5532 Touch Pad Not Working
Here are a couple of ideas from a Google Search: Press the key to the left of the On/Off button. The key has a picture of a finger pressing the touchpad. So simple, so elegant, so little information out there about it. https://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/my-touchpad-on-my-acer-aspire-5532-laptop-isnt/51f5de30-b465-e011-8dfc-68b599b31bf5?auth=1
12/23/2017 8:45:32 PM • Acer Aspire 5241... • Answered on Dec 23, 2017
Acer Aspire 5532 battery replacement charged initially, now says it's charging but stays at 0%
If these were both batteries bought online, say eBay... you may have been shipped defective product. If not, it sounds like the charging mechanism within the laptop is no longer re-charging your batteries. This will require a visit to your local computer repair shop most likely.
11/11/2017 12:36:02 PM • Acer Aspire 5241... • Answered on Nov 11, 2017
Screen upside down
If the mouse is also operating inverted then the video has been rotated by the video software. You can fix that by going into the video setup (nVidia/ATI Catalyst/Intel) and finding the rotation feature and re-inverting the image. If the image is inverted, but the mouse moves normally on the screen, then you have a haunted PC and should run for the hills!
11/10/2015 7:37:30 PM • Acer Aspire 5241... • Answered on Nov 10, 2015
When i turn laptop on it powers up...but nothing on screen...why?
Connect an external monitor to see if you have video. If you do then you may have a bad screen. Is there any visible damage to the screen? Does it flicker when you first turn it on?
5/28/2015 10:18:22 PM • Acer Aspire 5241... • Answered on May 28, 2015
Black screen when power on my acer laptop
hi try to isolate using external monitor, check connection of lcd cable replaced lcd panel
5/9/2015 9:13:33 AM • Acer Aspire 5241... • Answered on May 09, 2015
ACER ASPIRE 5532 RECALL
This is more than likely. Your local computer repair shop will be able to advise.
2/12/2015 9:00:25 PM • Acer Aspire 5241... • Answered on Feb 12, 2015
There is no power going into TOSHIBA Satellite L305-S5957 , have replaced charger but still nothing happenen when plugged in the charger light does not go on
Your saying the laptop will not power on without the battery, and just running on ac...or it will not charge the battery.
11/3/2014 7:38:25 AM • Acer Aspire 5241... • Answered on Nov 03, 2014
2answers
How do I start my acer aspire 5516
make sure the ac adapter is plugged in and start in the normal fasion, push the power button. Once you system comes up, allow for extra time for all the updates for the software you use, before using it.
10/13/2014 5:33:13 PM • Acer Aspire 5241... • Answered on Oct 13, 2014
Acer aspire
Technically, Yes. If there is damage to the wires but you know the AC-DC adapter is still good. There is a small single sided PCB inside the adapter that houses the transformer and step down/rectification circuit. There are two wires for the input (AC from wall which are hot and neutral) and two for the output which is your Ground and +18-19V (can't remember that particular voltage off the top of my head.) If you need to replace the plug that goes to the wall, check your plug type (the one that goes into the adapter) and order/buy a new one. That can be replaced with any plug that fits a desktop power supply. If you need to replace the plug that goes into the computer THEN you'll have to open the Adapter box. The two wires coming out of the board into the cable can be de-soldered. Just make sure you purchase the correct size/type tip (plug) for your computer and solder the positive and negative in where you removed the ones attached to the damaged cable. Once you have soldered your new cable onto the motherboard, use a good epoxy to seal the box back together. They are not "user servicable" therefore, there are no easy to snap on/off clips, you will have to use a good adhesive. Also, TEST YOUR OUTPUT BEFORE PUTTING IT IN YOUR COMPUTER!!! Read the bottom of the Adapter and see whether the center of the plug is positive or ground, connect your DC voltmeter accordingly and make sure that the output voltage matches what the adapter says. It may be .2-.3V higher than what the adapter says because there is no load (your laptop) on the output but as long as it's no further off than that, you're good! Good Luck! PS: There are capacitors in the adapter circuit that can hold a VERY large charge and potentially hurt or kill you! You can also completely destroy your power adapter if you do not know what you are doing. Find a couple of youtube videos on the subject, there's tons of 'em. I am not responsible for anything that you attempt without having the proper skillset. For anyone handy with a soldering iron and familiar with electrical circuits, it's an easy fix.
8/18/2014 7:06:50 AM • Acer Aspire 5241... • Answered on Aug 18, 2014
How can i get my touchpad K501Jseries working again??
I'm sorry but you may have been misdirected to my e mail some how,unfortunately I'm not the fix it guy you seek ,sujest that you reinterate w/ some one who may be qualified to ans. your questions.
7/4/2014 2:26:49 PM • Acer Aspire 5241... • Answered on Jul 04, 2014
2answers
BLACK SCREEN ON MY ACER 5532
Welcome to Fixya. I would like to know when you turn the laptop on is it running? Can you see the light that indicates that it is on?
We need to check if this is caused by a LCD or motherboard issue. If you can connect an external monitor on your computer and tap FN + F5. This will toggle the display. If you will be able to see the display on the external monitor it means that the problem is the LCD but if not then the problem is the video graphic that is embedded to the motherboard and to be able to fix it is to replace the motherboard itself.
Please let me know if you have questions. Thanks for using Fixya.
6/16/2014 9:53:34 PM • Acer Aspire 5241... • Answered on Jun 16, 2014
Don't have a camera icon how do i get to icon, have roll type cam/wsound jack activated
If you are using a recent Windows operating system, right click on the Start Button/Icon on the lower left of your screen at the end of your tool bar then click Properties. You will have a window pop up that should have three tabs. The left most tab (top of the window) says taskbar. Select that. Once that is open, click "Customize" (it won't have parentheses) which will give you a window with options of what icons should appear and when. Just find your camera and select when you want the icon to be visible and click Apply (or OK, depending on your OS) and you should be all set. You can also make sure that the device is powered on, when you connect it and if there is an installation disk that came with the device, be sure to use that. Always start installing a new device WITHOUT the device connected and follow directions until it tells you when to attach it. GOOD LUCK!
6/10/2014 12:26:30 AM • Acer Aspire 5241... • Answered on Jun 10, 2014
Hi, i was wondering if anybody could help. my acer laptop was not being used for lontime due to a broken screen. Now that i tried to use it from the external screen, it gives me an error message . Inp
turn off the laptop and then plug in the external monitor, and make sure you update the driver. It should work. My only other suggestion is to log in and access the device manager as administrator. I'm sorry I don't have more answers for you.
4/26/2014 8:26:07 PM • Acer Aspire 5241... • Answered on Apr 26, 2014
0answers
My Acer Aspire 5332 has stopped working cannot do
Tell me what happens, step by step, from the time that you first turn on the laptop until the problem occurs.
1/4/2014 6:22:56 AM • Acer Aspire 5241... • Answered on Jan 04, 2014
Stord 9 password
What is "stored 9"? so I can help with password.
1/4/2014 5:09:46 AM • Acer Aspire 5241... • Answered on Jan 04, 2014
Forgot stored 9 password
Forgot Acer Aspire password? I got Windows Password Recovery Tool Ultimate:
11/25/2013 1:44:16 AM • Acer Aspire 5241... • Answered on Nov 25, 2013
Acer Aspire 5241 5251 5332 5334 5338 5516 5517 5532 5541 5542 5551 5551G 5553 5553G ... (30034027032) AC Adapter Logo
Popular Tags
187 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • Acer Computers & Internet
Most Popular Question
stord 9 password
  • Computers & Internet
