you have to reset it .It is on the back off your.You need clipper a small penyou have to reset it .It is on the back off your.You need clipper a small pen
You can't post conmments that contain an email address.
oil your blade after each use. on the side there is a blade adjustment setting. after you oil the blade turn your clipper on, turn the set screw out a few turns till the blade is free. Then turn back in till it makes a loud clacking noise. Then u will back out the set screw till the baldes stop clacking and keep oiled well.
I had the same problem, beep beep beeeeep.
Take all your music from mp3 player to a folder in your PC and transfer it back to mp3 and that should do it
1.FIRST KEEP THE PHONE SUCH THAT THE SCREEN OF THE MOBILE FACES YOU..
2.now turn the mobile left 90 degree.. you can see a rubber strap,it ill be small
3.pull out and turn downwards,now insert the earphone (the earphone has a arrow to be inserted,so insert in that way) thats all..
if you have doubt mail me "[email protected]"
i ill post you the video link...
The part that holds the blades on came loose on my Classic 76 clipper. It turns out that the two holes for the inserts are too big. I fixed the problem by removing the inserts from the clipper body (easy since that is the problem), cleaned the inserts and holes in the clipper body and super glued the inserts back into the holes. Be careful not to use too much glue! It only takes a little.
This is from the Oster book: Changing Blades To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue. To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Ok turn your clipper on and hold it still in one hand whilst with the other hold the cable near the end of the clipper and bend it, rotate and twist if your clipper cuts in and out you have a break in the cable which is tricky to fit but our web site Help section can help.
Sometimes if the plug of earphones are inserted half way, only one of the earphones play. Please try to remove and insert again and see to that it is fitted in properly and completely.
