SOURCE: Keep Printed Documents
Deletes and reinstall print drivers, does'nt sound like a printer problem, more software issue, driver reinstall is my best bet
What are you printing from? ie program is?, and can you print windows test page OK?
SOURCE: unable to download pdf file
Uninstall all Adobe software what ever version you have, than go to start>search>all files and folders, select local hard drive if it is not, than click more advanced options, select first three things in the list and than type adobe in All or parts of the file name. When it finds folders and files select them all and press DELETE. Than empty your Recycle Bean and restart your computer once it is up download new Adobe installation file and install it again. I know that this is pain but you will have to get rid of all damaged files used by adobe reader.
SOURCE: won't print to printer - sends to a screen to save
Hi, I don't know if you've had an answer to this one yet, but when you ask your 'puter to print. The printing window that comes up, where you can choose number of copies etc, has a little tick box in the bottom (I think left hand) corner, that says print to file. If you uncheck the box, hopefully this will sort out your problem.
SOURCE: Bad file format (69) when importing jpg
Please update the QuarkXPress to 6.5 and 6.52 from the quark website and then check the results.
Also if these doesn't help then you can contact the Quark tech support to resolve the issue.
you can get the contact information from the website
SOURCE: Scanning documents
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (eg HP 6100c) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
File > Save as..
Hope that helps.
Chris (ziraffa)
hello. have you selected you're printer from the software exactly ?
