SOURCE: Denon UD-M50 cd changer. Need help extracting drawer for home repair!
Hi KathyKate
If you are still having the same problem with your
denon UD-M50 I might be able to help. I have fixed a number of them in
the past and have the necessary maintenance manual and knowledge of a
company that can supply spare parts. Disassembly looks very complex,
especially when the problem is with the carousel but once you have an
understanding of the mechanism it's not that difficult. Care should be
taken when manually removing and reloading the disc trays as damage can
result to the 'Teeth' alongside each. Spare trays are available. All my
repairs involved the removal of the carousel mechanism in order to
align the trays. I can copy the relevant sections of the manual dealing
with the re-alignment which is critical but again if followed exactly
you should have no trouble. If you respond with an Email address, I
will be only too pleased to forward you the schematics etc.
Regards Ibbotsnm
SOURCE: I have the Denon Personal
Your suspicions about a broken belts are probably exactly right.
Here's what you can do or attempt to do.
Make sure the machine is unplugged.
Remove the cover of the unit. You may be able to manipulate the cd changer mechanism so that you can replace the belts connected to the door mechanisms. Since I am not there and I don't know how your unit is constructed I would advise to be VERY patient and exacting while doing this.
DON'T FORCE ANYTHING. And use good lighting so you can observe how it functions.
I have replaced a lot of belts on various types of CD transports and there is a certain similarity they all have. Inevitably they all have some small belt that rotates a gear mechanism that moves the transport drawer or section in and out.
Of course you can get it serviced by a professional, who will do as I suggest. But if you are confident that you can do it. Have at it.
The only problem I can imagine is locating an electronics supply house in your area.
You may be able to get a full set of belts from Denon.
I hope this helps you.
Best Regards,
Mark
