A bunch of stuff could be happening. First did you format the new card if not see if it can be formatted to the camera. if not then you will need to download the newest updates for that camera from the Kodak web site. For example the camera is set )internally) to accept a 1gig card and you installed a 2gig card it won't recognize the card until the camera firmware is updated. The easiest way is to format the card first.
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
Note:
