Shaviya, what are you talking about regarding "modify"? If the disc spins and is not reading it, in general, that problem usually is the laser pick up assy either needs adj, cleaning or replaced. I don't know what in this world you are talking about. He is using original discs.Shaviya, what are you talking about regarding "modify"? If the disc spins and is not reading it, in general, that problem usually is the laser pick up assy either needs adj, cleaning or replaced. I don't know what in this world you are talking about. He is using original discs.
You can't post conmments that contain an email address.
Only the first version of the PS3 had PS2 backwards compatibility, They did make a special edition Metal Gear Solid version with it included but other than that no other PS3 will play PS2 discs... No matter what Add-On you install.
It's not able read the disc - try cleaning the disc, try another disc, etc to narrow down the problem. If it won't play any discs either the lens is dirty or an actual hardware failure in the unit.
Take the game out and see if the laser is towards the back. If so, pull the eye towards the spindle or where the hole of the game goes.....and clean the laser eye with a q tip soaked in alcohol.....
If your PS2 works fine with most
of the games and won’t play a few..Then you should try this trick to play them
too on your PS2:
Turn on your PS2 without
inserting any disc.
Menu screen will
appear like:
Press the (triangle) Button to enter Version
Information Menu that looks like
Highlight the Play Station
Driver as above and again press (triangle).
New screen will appear like
Highlight the Disc Speed
as above and press X button,to enter Disc Speed Menu
And set it from Standard to
"Fast".
After you set Disc Speed to Fast,Press and HoldReset Button to turn off your console.
Then again Press and Hold Reset
Button till the Blue Light turns on.
Remove the Reset Button and
Press it again.
Be
patient and wait till thegame loads itself. If your lens is in good condition then
it will play game in first go else try again till it PLAY your game. If still
your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens: Thank you and Good Luck!
I had the same problem with my ps2. I found a solution that might help you. take a Q-tip and dip it in rubbing alcohol or water just intil damp. gently clean the eye and the rest of the disk tray. then dry it the other end of the Q-tip. when the eye dirty with dust or a hair or a small speck of paper or plastic from a disk will slow the ps2 down when loading. hope this helps!
theres a difference in the older guitar hero games and newer ones, CD Rom for the older and DVD Rom for the newer, Ps2 wont read the DVD Rom ones, my experiance so far.
its a ps2 problem open the ps2 up if its a big ps2 not a mini and dust it the dust is making it harder for your ps2 to read disks open it dust it and itll be like barnd new if its a small ps2 i dont know dusting the thing always help dust with somthing small a cotton ball or ear swab will work
