Are you
forget to install sound driver during installing operating system on
your laptop? So first check that drivers are properly install or not. If
it is not install, install it. If already installed, try to update it.
Still
you are not getting any sound on your dell laptop so it also possible
that the sound card is possibly dead. If the computer uses on-board
sound (meaning there is no separate card with sound jacks on it), that
is more problematic. That part on the board cannot be replaced without
replacing the whole motherboard, normally. In either case, install a new
sound card and use its jacks for audio.
Feel free get the reliable technical help at http://www.vtechsquad.com/toshiba-support/ for troubleshoot all kind of Toshiba PC(laptop and desktop).
Are you
Still
Feel free get the reliable technical help at http://www.vtechsquad.com/toshiba-suppor... for troubleshoot all kind of Toshiba PC(laptop and desktop).
Method 1: Restart the computer Restart the
computer at least one time after you install a Windows Vista service
pack to verify that all processes related to the installation are
complete.
After you restart the computer, determine whether you
can hear sound. If you can hear sound, the issue is resolved. If you
cannot hear sound, try Method 2.
Back to the top
Method 2: Try another sound deviceIf
it is possible, try plugging a different sound device into the
computer. For example, if you were using speakers, try a different pair
of speakers or a set of headphones to make sure that the problem is not
related to the sound device.
Determine whether you can hear
sound. If you can hear sound, there is a problem with the original sound
device and the issue is resolved. If you cannot hear sound, plug the
original sound device back into the computer, and then go to Method 3.
Back to the top
Method 3: Unplug the computer speakersUnplug
the computer speakers or other sound devices that you may be using,
such as headphones, from the computer and then plug them back in to the
same port. Most sound cards that are compatible with Windows Vista
include a feature that detects sound devices plugged into the audio
jack. This procedure may prompt the audio detection feature to detect
and configure the sound device to make sound.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 4.
Back to the top
Method 4: Verify that the default sound device is set correctlyAfter
you install a Windows Vista service pack, you may find that the default
sound device, also known as the playback device, was changed. You may
also find that the sound quality has changed. Make sure that the default
sound device is set correctly for the sound device that you are using.
To set the default device, follow these steps:
If
the sound settings are set correctly, you are using speakers as the
sound device, and your speakers are already set as the default device,
go to method 5 now.
If there is a speaker icon next to the sound driver, the driver
is installed. If there is a yellow question mark next to the sound
driver, the driver is not present or will not loadhow can i fix my audio suon - uparrow.gif>Go to method 6 to reload the current sound driver and test for sound.
Back to the top
Method 6: Reload the current sound driver If
you discovered in method 5 that the sound driver was not installed, or
if you discovered that the how can i fix my audio suon - vistastartbutton.jpgtalled but is not
working, try to reload the sound driver. To do this, follow these steps:
Determine
whether you can now hear sound. If you can hehow can i fix my audio suon - uparrow.gifhe issue is
resolved. If the current sound driver did not reload or if it did
reload, but you cannot hear sound, try method 7.
Back to the top
Method 7: Update the current sound driver If
the current sound driver does not seem to be working, see whether there
is an updated sound driver that you can install. To request an updated
sound driver, contact the manufacturer of the sound driver.
You receive a message that states that a hardware device is
being installed, and then the uninstalled audio device appears in Device
Manager.
For information about how to contact hardware and software vendors, visit the following Microsoft Web site:
http://support.microsoft.com/gp/vendors/en-usNote
In some cases, the manufacturer may instruct you to uninstall the
current sound driver and to delete the driver files. To do this, follow
the steps in method 5, but at step 6, click to select the Delete the Driver Software for this device check box.
