Hotpoint 23 in. BF50 Built-in Dishwasher Logo
Posted on Nov 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leaking water from the corners of the front door
Anonymous
Level 3:
  • Hotpoint Master 43,501 Answers
  • Posted on Nov 30, 2010
Anonymous
Hotpoint Master
Level 3:
Answers
43501
Questions
0
Helped
10845275
Points
101584
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
My Crosley CS23B5 is leaking water out the front left (freezer side) sometimes lately. Why is it doing this now?
door is not shutting correctly, look for a bad door gasket or the door iasn;t sitting square in the fridge
Just installed the dishwasher and it is leaking from the the two front corners of the door
I dont know what brand your dishwasher is, but if it is leaking from the two bottom corners it is not level. If the back is higher than the front, the water will drip out of the bottom corners of the door. Raise the front feet up so that the edge of the door is flush with the cabinet doors from the top to the bottom.
Nov 20, 2010 • Dishwashers
1helpful
COVER ON DOOR DISPENSER IS LEAKING AT THE BOTTOM. WHAT COULD CAUSE THIS AND DOES THE COVER POP OFF?
The cover does come off, with some difficulty, but that will not help you. The leaking is caused by water build up in the collection tray, which when filled can leak out the front corners and down behind the outer frame. Use a bit of clear silicone to seal the front corners, and try to keep the drip catching recess cleaned out more often so it is not always full of water.
3helpful
Haier Washer/Dryer HWD1000 water leak from the bottom. When I turn the machine on, it starts taking water in, and then I see water leaking from the bottom..I checked the connection hoses, the door(front...
Check the button trap. Little door at front bottom right corner. There is a big screw in plug that has to be closed very tightly. Also check the plug gasket is clean.
1helpful
Water leaking from door: top left door of my french door fridge (with freezer on bottom)--water leaking from the very bottom right corner of that left side door
your drain is clogged. if ice isbuilt up in the freezeer floor. when the freezer defrosts and the drain is clogged it has no where else to go other than ouot the front. pull everything out of the freezer and check twards the rear at the bottom. remove as much ice as possibile let set unplugged and door open for 3 hours. then take a cup of boiling water and pour it back there. if it dont drain repeat that process with the water-have a towel ready because if the water stays back there long enough it will get cold. you need to keep the water HOT. ice could be built up in the drain. hope this helps
Dishwasher leaking
just an idea...if i'm understanding you correctly,could the door seal be creased there or folded over by use and age to permit this to happen? cause you said nothing is missing
Water leaking on floor at right front corner of
check the door rubber for any tears,this is also called a boot glove.
3answers
WATER LEAKING FROM FRONT BOTTOM
try onscrewing top panel on machine...when machine agitaes strongly a hose my pop lose up from top.
6answers
Fisher and paykel 913T soft touch dishwasher leaking
They do not have bottom seal, problem possibly is door cabinet seal or loose dispenser leaking, just had that problem woth one of those the other day
Aug 31, 2007 • Dishwashers
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
