Whirlpool GT4185SK Microwave Oven Logo
Posted on Nov 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My husband put a bowl of soup in our microwave and heated it up. When the soup had cooked, he tried to open the door, but the button does not work and the door does not open. We cannot get the soup or the bowl out and we can not open the microwave door. The oven is still heating up when we press the start button. How do we open the microwave to get the bowl out so we can have it repaired?
Anonymous
Level 3:
  • Whirlpool Master 43,501 Answers
  • Posted on Feb 25, 2011
Anonymous
Whirlpool Master
Level 3:
Answers
43501
Questions
0
Helped
10845744
Points
101584
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
2answers
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at [email protected] with your name, address, phone number and the model & serial numbers of the Microwave.
Microwave works while door open
Replace. Microwaves are cheap.
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
5helpful
The microwave will only work for 59 seconds then it stops. It is working but only for 59 seconds. I am not sure about the convection oven was afraid to try it. The unit is in our fifth wheel RV. I can heat...
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded them to our site here and here to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Microwave wont heat
look at the $2.00 door safety interlock switch(s) before you replace the very expensive (and hard and dangerous) magnetron.
2helpful
Microwave just stopped cooking!
The simplies is the fuse, which is located inside the unit, you need a screwdriver to open it
3answers
Microwave not turning on after egg explosion
repair door target wont accept return or repair under warranty due to damage by owner
Flashing red lights
It sounds like you are talking about the indicators as shown and explained on page 7 of your owner's manual.
The one that looks like windshield wipers (#10) is the microwave indicator. The ones that look like bowls of soup are the High Cook and Low Cook indicators (#24 & 25).
If you don't still have your owner's manual, you can download it here free. You will need the free Adobe Reader to view or print it.
Once you've looked that over, feel free to write back with specific symptoms if you're still having trouble.
Comes on when you open door, and now it finally quit working
I think you've put up with enough hassle from this unit and should get another one. Intermittant flakey problems are hard (read expensive) to fix.
Maytag Over the Range Microwave
Assuming the entire power line from the breaker to the microwave cord is okay, it's almost certainly a bad connection on the circuit board of the control panel assembly. For reference, we repair these from all over the country for $32.50 postpaid.
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
