SOURCE: JVC HR-S9700EK
Hi, This is a common problem with some VHS units. The problem is that the tape does not fully extend over the video head and the slack sensor shuts the unit off. This involves the motor and driving mechanism that actuates the spreader arms that moves the tape. Usually this is caused by slippage of a small rubber belt. Though the repair work involve is relatively easy, removing the mechanism and replacing the belt would require that you be familiar with component placement and certain timing sequence of tape loading. Your best bet probably would be to seek the services of a qualified professional. Hope this be of some help/idea. post back how things are or should you need additional information. good luck and kind regards.
SOURCE: JVC HR-S9500U
Power down unit and unplug. Wait 15 minutes and see if all functionality comes back. Accordianman
SOURCE: flashing auto display - won't power up
The infra red light in the middle of the mechanical deck, that powers the left and right photo sensors is not ok.It looks like a small lamp( you cant see it when it works-Infra red mind it).The video cassette has a large round opening in the bottom towords the front, and accomodates this lamp.please check it out.
SOURCE: HR-A37U remote won't work
It's not unusual for remote controls to stop functioning either partially or fully. To determine where the problem is, you will have to go through a process of elimination. The easiest way to find out where the problem lies is to purchase an inexpensive universal remote at a nearby store. Try the different codes and see if you can activate the VCR. If it works, you have the option of keeping the remote or returning it for another one if you cannot access all the functions of the VCR. I have seen exact replacements online for under $20.
If it does not work then the trouble is most likely in the VCR itself, unless the proper code could not be found in the universal remote, in which case you need to try another brand or model.
The only other suggestion I have for you would be to unplug the VCR from the AC power for at least 5 to 10 minutes and then plug it back in and try the original remote again.
I hope this helps, good luck.
