According to the manual a hard reset will erase all of the user data on the device and restore it to the factory settings. On the Palm Tungsten E2, you can do this by holding down the power button while pressing the reset button on the back of the device. When you release the power button, you will then confirm the hard reset by following the directions on the screen.
On your handheld, launch the Prefs application. Under General, select Security.
If the Password box says "Unassigned," tap the box and create a password for your handheld.
Once the password has been set, remove the stylus. Disconnect your handheld from the AC charger, if connected.
On your handheld, hold down the Power button.
While holding down the Power button, use the stylus to press the RESET button on the back of your handheld.
