When I turn my camera on there is a line through the flash symbol and a yellow camera with an exclamation point. The flash is not working so when I take pictures inside they're fuzzy. Does anyone know what's going on and how to fix it? Thank you
A yellow explanation point symbol on the dashboard typically applies to the Tire Pressure Monitoring system. A thick ! inside a half drawn flat tire symbol to be complete and comes in yellow color when lit. Under normal vehicle set-up, if this indicator stays lit after the power-on selftest, you need to check your tires for any uneven pressures and adjust their pressures to correct specifications. Okay? : )
A red exclamation point inside a circle when lit indicates your parking brake is on, or your brake fluid level is low.
I just looked it up in my manual, and the exclamation mark with the waving hand means: 'There is a strong likelihood of camera shake because the shutter speed is slow.' The remedy to this is: 'Use flash photography. However, use a tripod for some scenes and modes.'
It sounds like you need to adjust your shutter speed. I'm no expert and I consult my manual often, so if you need any assistance doing this or anything else, feel free to ask.
If it is yellow and looks like a tire it is the flat tire light, and you should check his tire pressure. if it is a yellow triangle with an arrow going around the triangle with a exclamation point in the middle this is your DSC or ASC and if it is on all the time these features are inactive and you should hit the DSC/ASC toggle switch to the right of the drivers window switch. If this symbol just flashes briefly this means the DSC/ASC is presently activating. thest are the tow that I can think of, I hope this helps.
