it may be the power supply itself! have any of you tried using a different power cord? the problem may not be in the printer but in the cord itself. i have 2 hp 6310's that were giving me the 'reset power' error. when i changed the POWER CORD, that error message went away and it went into the insert cartridges mode. good luck.
Your printer is trying to talk to you, in its own limited way. If you are able to find the manual for the printer, it will list out all of the possible blinking light combinations, and a somewhat detailed summary of the problem. If you cannot find the manual, HP does have these available on their web sites. If you can either refer to the manual to see which blinking light combination is happening, or you can describe exactly the combination of lights, and the frequency (fast or slow, steady of intermittent, I can assist you better with determining the cause.
HP 6310 Reset There are 3 types of resets in the printer 1.Partial Reset 2.Semi full Reset 3.Full Reset To do partial Reset.
1. Unplug the power cable and turn off the the unit. 2. Press and hold # & 3 at the same time with out connecting the power cable. 3. While holding the button, connect the power cable and do not the release button for 5 sec. 4.Then turn ON the unit To do Semi full Reset.
1. Unplug the power cable and turn off the the unit. 2. Press and hold # & 6 at the same time with out connecting the power cable. 3. While holding the button, connect the power cable and do not the release button for 5 sec. 4.Then turn ON the unit. To do full Reset.
1. Unplug the power cable and turn off the the unit. 2. Press and hold # & 9 at the same time with out connecting the power cable. 3. While holding the button, connect the power cable and do not the release button for 5 sec. 4.Then turn ON the unit
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
Ok try unplugging the printer for about 15 minutes and plug it back in that will reset the printer and it should work fine.
Let me know how it works out
The solution to this problem is to have a Class-Action-Lawsuit against HP.
The idea that HP can sell ten's of thousands of these kind of defective products that just to end up in a Land-Fill is not only immoral but also ILLEGAL.
