I have a fan assisted oven that has started to be very noisy. Slamming the door stops it for a while but does not help the yorkshires. Any advice please.
Sound like the element has burnt out but if your fan is also noisy it is probley running slow which may have caused the element to overheat and burn out so it would be a good idea to replace the element and the fan motor
If it is the fan that is noisy, check for loose fan or the fan blades catching the cover, if all o/k, then it will probably be a worn fan bearing, only solution would be to replace the fan motor.
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Make certain that the heating element is properly seated WHEN THE OVEN IS COLD! When you put "current" through wires and heating elements, they vibrate. Zip tie the wires together outside the oven cavity.
If it is a fan assisted oven , then it sounds like a noisy oven fan.
It could be a worn or dry bearing in the fan motor. if you open the oven door , you should be able to tell if it is the fan by listening to it carefully.
The other possibility is if it has a cooling fan in the back or on the top of the oven, it could also be that causing the prob, these are about the only things that could be making a noise, as there are no other moving parts that could make a noise.
PLz rate my solution.
