20 Most Recent Neff U1721 Double circotherm Electric Oven Questions & Answers
No power to neff bottom oven
Bottom oven is directly linked to the clock, If the clock is on but not set ie 0:00 or 12:00 flashing it won't work, set the time (doesn't have to be right, just not flashing) try oven again. If this is not the problem please contact me again and we'll look further. Cheers
11/9/2022 10:31:05 AM • Neff U1721... • Answered on Nov 09, 2022
Fan oven element - HEEELLLLPPPPP !
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
1/17/2022 3:08:32 PM • Neff U1721... • Answered on Jan 17, 2022
Unable to remove the fan blade on the neff u1721 oven (too tight)
The nut is a left hand thread, so unscrew it clockwise to release it, hold fan blade as you are doing this. Tighten anti- clockwise.
Plz rate my solution.
Thanks.
1/17/2022 3:06:08 PM • Neff U1721... • Answered on Jan 17, 2022
Fitting a new heating element Neff U1721
You need to remove the element from inside the oven cavity, but it is a bit of a fiddle. Once you have removed the screws at both ends of the element you need to remove the fan blade to access the centre fixing screw. Once all srcews are remove you have to twist the element and pull forward to remove the wires from the hole on the left, then remove the wires and refit to new element.
1/17/2022 2:47:28 PM • Neff U1721... • Answered on Jan 17, 2022
Hello. I am trying to replace
It should just pull off, try spraying some wd 40 onto the spindle, or apply some heat to the fan to expand it with a blow lamp or hot air dryer.
1/17/2022 2:46:12 PM • Neff U1721... • Answered on Jan 17, 2022
2answers
Main oven won't turn on
I'm figuring you've probably resolved this, since you posted in November (and I've just joined the site today). However, I thought I'd post a solution just in case anyone else surfs in and finds the same problem.
We have the same sort of oven. After the power has been off, the oven won't work until you set the time on the clock. I think it's because of all the automatic timer features.
On ours, you have to press the two buttons with arrows on at the same time as turning the clock dial to change the time.
Good luck.
8/10/2018 6:18:20 PM • Neff U1721... • Answered on Aug 10, 2018
More likely the heater element.. I hope this helps...
2/21/2018 2:56:38 PM • Neff U1721... • Answered on Feb 21, 2018
Neff u17 built-under causes fuse
There could be a fault in the lower oven , or it could be overloading the circuit. add the watts of the two elements and divide by line voltage, this will give amps , now check the fuse rating amps , it must be higher than the oven. If that checks out ok the fault is in the oven.
1/3/2018 7:44:19 AM • Neff U1721... • Answered on Jan 03, 2018
0answers
U1442 main oven not heating
If you are sure there is 220v going to unit, it most likely is element or click / control. If you have a ohms meter, you can test the element
9/7/2017 7:44:19 PM • Neff U1721... • Answered on Sep 07, 2017
After effects of blown fan oven element on U1721
I think there is an inline fuse for each oven/element.
5/4/2017 5:11:46 AM • Neff U1721... • Answered on May 04, 2017
0answers
2answers
MY NEFF DOUBLE OVEN IS ABOUT 8 YEARS OLD I HAVE
it sounds to me that the fan is not working properly. as the oven gets older the fans become weaker and then doesn't blow air over the element at a rate that can the temp down enough..
regards
Richard Saupe
http://www.saupe.co.uk
Oven Specialist
4/6/2015 9:33:47 PM • Neff U1721... • Answered on Apr 06, 2015
Neff oven range Fan oven element changed .No power
See if the toc is open circuit , it is situated just above the heater connectors at the rear .
3/6/2015 8:14:33 PM • Neff U1721... • Answered on Mar 06, 2015
0answers
Neff U1721 Double circotherm Electric Oven Logo
245 questions posted
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
john h
Are you a Neff Oven Expert? Answer questions, earn points and help others
View Most Popular
Neff Ovens
  • Neff Ovens
Most Popular Question
hi
  • Ovens
