Just bought this JVC KD-G200 system from a pawn shop its all hooked up double checked to make sure its correct everything works but no sound on anything CD PLAYER OR RECVEIVER AM or FM any ideas!
Thi JVC KD-G200 does not have an auxiliary input, or aux mode. If you want to play audio from an external device through this unit, you will need a FM transceiver.
Check to make sure the antenna wire is attached to the back of the radio. Also there should be a source button that switches to 3 different preset settings. Try using this. If there is still a problem, let me know.
Have you checked the fuse-box to make sure that you didn't blow the fuse for the radio? Also try removing the radio and checking the wiring to ensure that it is tight. There is also a fuse on the back of most radios to check!!
Type in the code shown at the bottom.
Click "download now"
Click where it says "link" in blue.
Click "save"
Save the pdf to your computer's hard drive.
Instructions are as follows:
Press and hold the "select" button for more than 2 seconds.
Press the "fast forward" icon button.
Turn the dial to appropriate hour.
Turn the dial to appropriate minutes.
Press the select button.
could have blown the speakers or if there sub woofers ran off an amp that might be your problem as far as the cause it could be something as simple as a loose ground or some wire that is getting power grounding out on a piece of metal somewhere i would double check all of your connections
