If your solder joints are good and no solder has slopped over to short it out, the only thing left to check is the polarity of the battery. Positive end goes toward the motor
Polarity is good. Solder job on the end is good. - end is a little sloppy but not really much overflow. I guess i can try soldering a different battery and see if anything changes. Any other ideas? Is it that I can't use just an energizer nimh rechargeable for some reason?
If it is the correct rated battery, it should work. Make sure no solder dripped onto the circuit board whene it shouldn't be. I have installed many thousands of batteries and there has never been a 'defective' battery. You will find the battery that is made for your shaver at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replaceme...
The 7340XL uses a LiIon 14500 battery, not NiCd or Nimh. Different voltage. The new battery was being overcharged.
