20 Most Recent Zadro Surround Light 10X/1X Satin Nickel Vanity Mirror SLV410 Questions & Answers
How can I find the Owner's Manual for Raycine Clippers model 274 series A?
Call Oster: 800-339-2547 (9-5 ET)
10/2/2022 5:13:41 PM • Health & Beauty • Answered Yesterday
What does EE Mean on Boots bp machine?
The cuff is too loose. The reason for the EE Error Indicator is generally caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. ... This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. They are made by Omron. https://www.testsymptomsathome.com/OMRC1_FAQ_FAQ.ASP?ItemID=OMRC1 ..
10/2/2022 1:03:01 PM • Health & Beauty • Answered Yesterday
2answers
What is Hiateous hernia?
It is a gastrointestinal matter than is usually from over eating, eating spicy food and eating too quickly and the stomach acids creep up into your throat upper chest area and the burning if these acids will make you feel that you may be having a hear attack.
Stop eating meats, deli meats and too much food for 3-5 days and take tums or alternatives to stop the burning feeling.
10/1/2022 4:41:52 AM • Health & Beauty • Answered 2 days ago
Can I fix myself? Green light scooter charge problem.
The charging system on an electric scooter is very basic. You put 12 volts, 6 amps into the battery via a charger. The charger plug connection makes sure you get the polarity right. If you have a digital multimeter you can check the voltages from the charger and the voltage held by the battery. A 'Green Light', is usually a good sign, but in neither of your posts do you tell what the problem is except that you have a black wire that has come adrift from a 'board' (I presume that is what the word 'botd' was supposed to be, so I edited it). That needs reconnecting, or contact your local dealer for service. Full 'make and model' and '(what it is)' in all questions please. I am guessing it is a mobility scooter, but there are 2 others types in common usage at the moment.
9/30/2022 7:47:48 PM • Health & Beauty • Answered 3 days ago
3answers
Brookstone max massager stopped working
What should we do when it does not massage
9/29/2022 7:00:03 PM • Health & Beauty • Answered on Sep 29, 2022
My eclipse mobility scooter keeps going into limp mode when it goes over a slight bump
I would check the brushes.
9/29/2022 12:08:20 PM • Health & Beauty • Answered on Sep 29, 2022
10answers
How can I avoid toothaches?
Take care of your oral health by eating healthy food and brush properly. Go for regular dental visits.
9/28/2022 9:48:13 AM • Health & Beauty • Answered on Sep 28, 2022
What is vertin 16 Tablets and uses, side-effects
Vertin 16 Tablet is used to prevent and treat M?ni?re's disease, an inner ear illness. Dizziness (vertigo), ringing in the ears (tinnitus), and hearing loss are all symptoms, which are most likely caused by fluid in the ear. This medication relieves symptoms by decreasing the quantity of fluid in the body. Vertin 16 Wesbite Visit:- https://firstmeds.in/drugs-a-z/vertin-16/
9/27/2022 7:58:52 PM • Health & Beauty • Answered on Sep 27, 2022
What is Dexona Tablet and uses, side-effects?
A group of medications known as steroids includes Dexona Tablet. It is used to treat a variety of diseases and ailments, including cancer, autoimmune disorders, and inflammatory problems. Dexona Tablet reduces inflammation by stopping the production of chemicals that produce swelling, redness, discomfort, and itching in the afflicted area. To prevent stomach distress, it should be taken with meals. The efficacy of the medication is increased by taking it often and at the appropriate times. Until your doctor advises you it's okay to quit, it's critical to continue taking the medication as prescribed. Dexona Tablet Wesbite Visit:- https://firstmeds.in/drugs-a-z/dexona-tablet/
9/27/2022 7:57:35 PM • Health & Beauty • Answered on Sep 27, 2022
What is Zerodol SP and Uses, side-effect
A combination **** called Zerodol-SP Tablet is used to treat a variety of problems such post-operative pain, joint pain, and muscular pain. As a result, it successfully treats rheumatoid arthritis, ankylosing spondylitis, and osteoarthritis-related pain and inflammation. The dosage and duration of Zerodol-SP Tablet should be followed as prescribed by your doctor. To avoid stomach distress, it should be taken with food or milk. The efficacy of the medication is increased by taking it on a regular basis at the appropriate periods. It is important to continue taking the medication as prescribed until your doctor advises you to stop. Some of the frequent adverse effects that may be experienced when using this medication are nausea, vomiting, stomach discomfort, indigestion, heartburn, lack of appetite, and diarrhoea. If you are taking this medication for a prolonged period of time, your doctor may frequently check your levels of blood components, liver function, and kidney function. Serious side effects, including as gastrointestinal bleeding and renal issues, may result from prolonged usage. Zerodol-SP Wesbite Visit:- https://firstmeds.in/drugs-a-z/zerodol-sp-tablet/
9/27/2022 7:56:00 PM • Health & Beauty • Answered on Sep 27, 2022
My scooter runs normal then slow down then speeds up then slows down again
Hi, Please ensure that any filter in the scooter is cleaned or empty . And check any visible gears for crud that needs to me removed. Then,, you can call the manufacturer for any necessary maintenance if the first steps don't work. Thank you.
9/27/2022 6:12:57 PM • Health & Beauty • Answered on Sep 27, 2022
3answers
Osim imedic 500 chair controller only displays: er how to fix?
massage chair er is "error message" .....not much help lots of components that can fail on a masage chair look for the user manual index-omyln5yzcl4rshihar4so15z-3-0_0.jpg
9/26/2022 5:22:34 PM • Health & Beauty • Answered on Sep 26, 2022
2answers
Got spots on my lower back
If you haven\'t had chicken pox as a child then adults certainly can contract it. The greater risk in adults is though is that the virus responsible for chicken pox can also cause shingles. This is a much more serious illness. Measles is also possible to contract as an adult. Did you have the MMR vaccine? If so, then it is unlikely that you have contracted either measles or chicken pox. Symptoms of measles generally appear within 14 days of exposure to the virus. Symptoms include: People with chickenpox have the following symptoms before the rash appears:
  • Fever
  • Headache
  • Stomach ache
The chickenpox rash occurs about 10 to 21 days after coming into contact with someone who had the disease. The average patient develops 250 to 500 small, itchy, fluid-filled blisters over red spots on the skin.
9/26/2022 9:12:48 AM • Health & Beauty • Answered on Sep 26, 2022
What should I be eating to support a healthy gut?
Fresh fruit, vegetables, meat both red and white with a minimum amount of processed food.
9/23/2022 1:28:11 PM • Health & Beauty • Answered on Sep 23, 2022
3answers
What is Forskolin extract?
It is an extract of the Coleus plant that has been known for hundreds of years as a herbal remedy for just about anything. Hard data on its actions in regard to weight loss and appetite suppression is difficult to find, as few clinical trials have been done. Consequently the promoters of this stuff say things like "MAY do this, MAY assist in...." etc It is known to be dangerous when taken in combination with certain drugs prescribed for high blood pressure (often seen in obese people), heart problems, or blood thinners, eg warfarin, aspirin, ibuprofen etc.
9/22/2022 4:33:09 AM • Health & Beauty • Answered on Sep 22, 2022
2answers
Can I take steroids for chest infections while on sertralin and blood pressure tablets
no you take antibiotics under a doctors instruction
9/20/2022 9:56:05 AM • Health & Beauty • Answered on Sep 20, 2022
Zadro Surround Light 10X/1X Satin Nickel Vanity Mirror SLV410 Logo
0 questions posted
Top Zadro Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Tom Chichester
Are you a Zadro Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Zadro Health & Beauty
Most Popular Question
replace
  • Health & Beauty
