20 Most Recent Sungold ST-8000 Portable Air Cooler Purifier Fan Humidifier Questions & Answers
0answers
2answers
My scooter jerks when I try to go full throotle why?
could be that the throttle pot is faulty or the motor needs a service, try a service first as this is the cheaper option.
3/29/2023 7:37:19 PM • Health & Beauty • Answered Yesterday
2answers
Could Lansoloc be used as antibiotic?
Ulcer is fully curable even without taking medicines.
If anyone really has ulcer pls let me know. I will cure it online just by acupressure
3/29/2023 8:17:42 AM • Health & Beauty • Answered Yesterday
Remove batteries from the battery pack on a ultralite 480 mobility scooter
Tony, It is evident that you didn't remove the batteries in the first place. The batteries are hooked up in series meaning that 1 battery uses the positive cable, the negative on the same battery connects to the positive on the other battery and the terminal left is the negative for the system.
3/26/2023 5:31:24 PM • Health & Beauty • Answered on Mar 26, 2023
Invacare TDX SP2 Wheelchair keeps spinning in circles?
There are a few potential reasons why an Invacare TDX SP2 wheelchair might start spinning in circles. Here are some possible causes and solutions:
  1. Calibration issue: Sometimes, the wheelchair's control system can become slightly out of calibration, causing it to spin in circles. Try recalibrating the joystick controls by following the instructions in the user manual.
  2. Loose connections: Check to make sure that all of the wiring connections are tight and secure, as loose connections can cause intermittent issues with the wheelchair's operation.
  3. Wheelchair batteries: Make sure that the wheelchair batteries are fully charged and in good working condition. If the batteries are low or damaged, this could affect the wheelchair's ability to move in a straight line.
  4. Mechanical issues: There could be a mechanical issue with the wheelchair's wheels or motors that is causing it to spin in circles. You may need to take the wheelchair to a certified repair technician to diagnose and fix the issue.
If none of these solutions work, or if you're not comfortable attempting to diagnose and fix the problem yourself, it's recommended that you contact Invacare customer support or a certified repair technician for further assistance.
3/15/2023 8:14:39 PM • Health & Beauty • Answered on Mar 15, 2023
2answers
METLER TOLEDO SCALES POWERS DOWN AFTER I ENTER TARE
It sounds like a power issue.
User Manual - Mettler Toledo
Mettler Toledo https://www.mt.com > ind > IND_PDF > manuals PDF After switching off/on or after a power interruption, the device continues to work with the saved zero point and tare value. Page 26. Settings in the menu. 22.
3/15/2023 12:33:40 PM • Health & Beauty • Answered on Mar 15, 2023
I turned on my tanning bed lights came on . Fans on them it started beeping and lights go off , fans stay running. Had to shut off breaker to make beeping turn off
If your tanning bed is beeping and the lights are turning off but the fans are still running, it is possible that there is a malfunction with the bed's control system. Here are some steps you can take to troubleshoot the issue:
    1. Check the power source: Ensure that the power cord is plugged in securely to the outlet and that the outlet is functioning properly. If you have a dedicated circuit for your tanning bed, check to see if the circuit breaker has tripped. 3. Check the bulbs: Inspect the bulbs for any signs of damage or wear. If the bulbs are old or have cracks, they may need to be replaced. 4. 5. Check the timer: Make sure that the timer is set correctly and that it is not malfunctioning. If the timer is not working properly, it may need to be replaced. 6. 7. Check the bed's manual: Consult the owner's manual for your tanning bed to see if there are any troubleshooting steps or error codes listed that may help you diagnose the problem. 8. Contact the manufacturer or a professional technician: If you are unable to diagnose or fix the issue on your own, it may be best to contact the manufacturer or a professional technician to assist you with repairing the bed
3/14/2023 10:44:02 PM • Health & Beauty • Answered on Mar 14, 2023
What is the difference between staying in assisted living community or home and independent living community as far as seniors are considered?
Aware of when it comes to the care you can expect to receive in both settings, whether you're admitted into a hospital or you or a loved one are thinking about moving to a home care services Abu Dhabi.
3/11/2023 1:29:23 PM • Health & Beauty • Answered on Mar 11, 2023
Solar System 32 Tanning Bed. On the timer board there is a red tab that is made into the board, the red tab is fried. Can this be fixed or do I need to order a new board. New one is 500 bucks!
Question edited for clarity and 'make model (what it is)' This appears to be a Tanning Bed so I moved it from the Televisions Category to Tanning Beds - Health and Beauty. The 'Red Tab' is presumably an electrical component soldered to a board, something like Power Triac. or similar. Take it to an electronics shop and they can replace the component. The beds are nearly $3,000 so worth repairing. https://www.google.com/search?q=solar+system+32 https://www.google.com/search?q=electronics+engineer+near+me ..
3/8/2023 6:11:23 PM • Health & Beauty • Answered on Mar 08, 2023
What method can lower blood pressure quickly?
There are several methods that can help lower blood pressure quickly, including:
  1. Deep breathing: Take slow, deep breaths for a few minutes. This can help relax your body and lower your blood pressure.
  2. Exercise: Engage in some physical activity, even if it's just for a few minutes. Exercise can help lower blood pressure by improving blood flow and reducing stress.
  3. Drink water: Drinking water can help reduce blood pressure by increasing blood volume and reducing the concentration of sodium in the blood.
  4. Limit caffeine intake: Caffeine can increase blood pressure in some people, so it's best to limit your intake of coffee, tea, and other caffeinated beverages.
  5. Reduce stress: Stress can raise blood pressure, so try to find ways to relax and reduce stress. This can include deep breathing exercises, yoga, or meditation.
  6. Take medication: If your blood pressure is dangerously high, medication may be necessary to quickly lower it. Consult with a healthcare professional before taking any medication.
It's important to note that these methods may not work for everyone and should not replace medical treatment for high blood pressure. If you have concerns about your blood pressure, consult with a healthcare professional.
3/3/2023 10:14:55 AM • Health & Beauty • Answered on Mar 03, 2023
4answers
How to test your sugar levels at home
go to your doctors and get a diabetic test kit prescription from your chemist / pharmacist they will supply you with a test kit and test needles using the machine supplied pierce the skin of a finger and put the machine sensor on the blood and check the reading on the screen make sure that you get all the sheets from your doctor as sugar levels are critical and should only be done with a doctors knowledge if you are in a country that doesn't have a diabetic support system, work more closely with your treating doctor
3/2/2023 11:13:54 AM • Health & Beauty • Answered on Mar 02, 2023
Sungold ST-8000 Portable Air Cooler Purifier Fan Humidifier Logo
1 questions posted
Top Sungold ST-8000 Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Sungold ST-8000 Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Sungold ST-8000 Health & Beauty
Most Popular Question
homemedics massager controller
  • Health & Beauty
