Using your model and serial number, use this link to view a service manual with procedure instructions. http://www.sportsmith.net/
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
SOURCE: belt replacement for precor efx 645 verison 1
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
SOURCE: I own a Precor EFX 5.33 the drive belt snapped so
You use the two bolts that hold the step up pulley in place. The step up pulley is the pulley assembly that is closes to the back of the unit. The step up pulley slides into two grooves in the frame, then there is a bolt on each side that run down the groove into the step up pulley. These bolts are the bolts that adjust the tension for the skinny belt. You may need to loosen the other belt first then tighten the skinny then retighten the belt you replaced.
SOURCE: How do I replace the
Check this reference guide in video: Precor+elliptical+trainer+change+belt
Hope helps.
