20 Most Recent
Precor 9.31 Treadmill Questions & Answers
Treadmill shuts off in middle of workout
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend replacing the motor controller,walkbelt,deck and applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
How to replace a Treadmill Precor 9.31 belt
Replacing a Treadmill Running Belt and Deck
Following is a basic guideline of removing and replacing the
running belt and
deck on a treadmill. Due to different brands and designs of treadmills, the following should only be used as a guideline. If any of the information is not exact to the treadmill being serviced, refer to the service manual or call Sportsmith for further help.
Tools Needed: Phillips Screwdriver, Set of Allen Wrenches, Set of Box End or Open Face Wrenches (Tools needed may vary depending on treadmill. )
- Switch the Power off on the unit.
- Next, unplug the unit from the wall.
- Remove the finger guard retaining screws and carefully remove the finger guards from the deck at each end of the rear roller.
- Loosen each rear roller bolt by 10 full turns. Then count the remaining turns necessary to remove the rear roller bolts. Remember to write down the number of turns needed to remove the bolts in each side for future reference.
- Carefully remove the rear roller from the unit. Clean any wax or debris buildup from the roller and place it aside.
- Raise the shroud and secure it with a bungee cord.
- Work the drive belt off the motor pulley by hand turning the flywheel while pushing the belt aside.
- Now remove the front roller retaining bolts.
- Carefully remove the front roller from the unit. Clean off any wax or debris buildup and set it aside.
- Loosen and remove the deck mounting hardware.
- Move the deck toward the left side of the frame to free the deck from the right side. The deck will move down once the frame has been cleared.
- Remove the deck and belt by raising the right side edge of the deck over the frame rail and sliding it to the right to remove.
- When installing a new belt or deck it is important to note that a new belt and deck surface should always be installed together. Failure to adhere to this guideline will severely shorten the life of the newly installed parts. Some decks can be used on both sides. However, be sure that each side is only used once. Be sure to install the belt in the proper direction on the unit.
- Install the belt and deck by first putting the belt on the deck, and then installing them from the right side as a unit.
- Be sure the deck is lined up with the frame and push the deck to the left side.
- Now carefully lower the right side of the deck to insert it into the frame rail and then push the deck to the right as far as possible.
- Re-install deck mounting hardware. (Check with mfr. for proper torque during install process.)
- Carefully place the front roller on the deck under the belt and push it forward into place, while placing the drive belt on the inside of the drive pulley.
- Replace the front roller bolts. (Check with mfr. for proper torque during install process.)
- Now spin the roller by hand while pushing the drive belt onto the pulley. Be sure to spin the roller several times to insure complete installation of the drive belt on the pulley.
- Install the rear roller into unit. Carefully start each bolt and turn one to two threads to ensure no cross-threading has occurred.
- Tighten each rear roller bolt the number of turns you kept earlier for reference.
- Now, Plug in and power on the unit.
- Carefully remove the bungee cord from the shroud and lower it back into place.
- Start the unit at a very slow speed and check for proper belt alignment. Remember to start at the slowest speed possible and be ready to stop the unit quickly if needed.
- If the belt is moving to right side of unit tighten the right roller bolt, If the belt is moving to the left side of the unit tighten the left roller bolt until the belt is tracking properly.
- Caution: make very small adjustments such as 1/4 turns and then watch the belt for several moments before making another adjustment.
- Once the belt is tracking properly walk on the unit at a slow speed and check for belt slippage on foot fall. If this is happening tighten each of the rear roller bolts equal turns until the slippage is no longer occurring. Caution: make very small adjustments such as ¼ turns and then watch the belt for several moments before making another adjustment.
- Now use the unit at a jogging speed to check for belt travel or slippage.
- If slippage still occurs make small equal adjustments (1/4 turns) to both sides of rear roller and re-test.
- Install the finger guards once you have enough clearance from the rear roller.
- Some manufacturers require wax or lube during the install process, please consult your owner's or service manual for further information regarding this.
- This concludes our instructions of how to install a replacement treadmill belt and deck.
How to Replace Treadmill Running Belt and Deck
Password reset
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
What is the password the get the precor 3.1 treadmill to work?
• Set User Name
Procedure
Thermal overload on motor keeps tripping around
I would check out the condition of your belt and deck.
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
When I move up the speed to 8.1 from 7.5 machine powers off
You may consider checking the condition of your belt and deck. The motor has to work harder when there is excessive friction between the deck and the belt -- in some cases, the motor overheats and will turn off or it can sometimes cause the breaker to trip.
Precor treadmill has Error 42
Precor Error Code 42
Error Code: 42
Manufacturer: Precor
Model: All Models
Error Description:
Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40.
Possible Reason:
Bad or intermittent connection in the lift motor controller.
- The lift motor requires calibration.
- The lift motor potentiometer is bad.
- The lower PCA to upper PCA cable is bad.
- The lower PCA is bad.
- The upper PCA is bad.
Recommended Action:
- Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
- Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
- If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
- Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
- Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
- Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Precor Error 40, No Lift Motion Detected
Probable Cause
1. Blown lift fuse in lower PCA.
2. Lift motor is physically jammed and not able to move.
3. Bad lower PCA.
4. Bad lift capacitor.
5. Bad lift motor winding.
6. Bad interconnect cable between upper and lower PCA.
7. Bad upper PCA.
Corrective Action
- Check the lift fuse from the lower PCA. Using an ohmmeter, the fuse should measure 1 ohm or less. If the reading is significantly high, replace the fuse. If the fuse is open, refer to steps 3 and 4 before continuing.
- Disconnect the lift motor from the ramp (elliptical) or lift platform (treadmill). If the lift nut or lift tube is jammed against the motor housing, turn the lift tube or lift nut away from the motor housing. If the lift was jammed, refer to step 3 before continuing. Calibrate the lift motor per the proper procedure for the unit being serviced and reattach the lift motor to the ramp (elliptical) or lift platform (treadmill). NOTICE: You must find and repair the cause for the jammed lift. Only re-calibrating the lift motor will not solve the problem.
- One of two modes can cause the lower PCA to fail. The lift switch could fail in an operated condition. If this happens the lift will move (either up or down) as soon as the unit powers up. The usual result is that the lift will be physically jammed as explained above, and probably also being cause for the lift fuse to blow. The lift switch could also fail in an open condition. If this happened, the lift would not operate in one direction. If either of these conditions occur the lower PCA needs replaced.
- Most units have the lift capacitor mounted inside the lift motor, and others use external lift capacitors. This information applies to units with the external lift capacitors. If the lift capacitor is shorted the lift fuse blows. Check the capacitor for a short using an ohm meter. Disconnect the capacitor from the lift motor and test. A good capacitor reads in the millions of ohms. Replace the capacitor if the reading is significantly low. Capacitor can also fail in the open condition which would result with the lift motor trying to run but not having normal power. Test the capacitor by measuring AC voltage across it. A good capacitor will read AC peak voltage while an open capacitor reads AC RMS voltage.
- When a lift motor winding is bad the lift will not operate in one or both directions depending upon the exact fault in the motor. Check the lift motor winding with an ohm meter. AC lift motors have a split winding (3 wires) and DC lift motors will have a single winding. Both windings must be checked on an AC lift motor. Normal winding readings could vary anywhere between 1 and 60 ohms, depending on the lift motor being tested. See the proper service manual for the motor being tested.
- Test unit with a known good interconnect cable. Replace the interconnect cable if necessary.
- Test unit with a known good upper PCA. Replace the lower PCA if necessary.
Precor Error Code 40
Lift Position Value Out of Range Precor Error 42
My Precor 9.31 has error 42 displayed and will not go away by holding down the QuickStart button;what is the next step?
Error Code: 42
Model: All Models
Error Description:
Possible Reason:
Recommended Action:
Speed goes fast than slow than fast- error code 22
Precor Error Code 22
Error Code: 22
Model: All Models
Error Description:
Error 22, No Motor Pulses at Start Up - Error indicates that the display has sent a command for the drive motor to start, however, the speed sensor has not returned the signal acknowledging that the drive motor has started.
Possible Reason:
- The line of sight between the speed sensor and the speed sensor target is obstructed.
- Badly worn drive motor brushes.
- Incorrect gap between the speed sensor and the speed sensor target.
- Incorrect adjustment of the speed sensor potentiometer (when equipped).
- Inoperative speed sensor.
- Faulty lower PCA.
- Faulty interconnect cable between upper and lower PCA.
- Faulty upper PCA.
Recommended Action:
- Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
- Bady worn drive motor brushes cannot make proper contact with the motor commutator, therefore the drive motor will not start when voltage is applied. Inspect and replace drive motor brushes if necessary.
- Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
- Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
- An inoperative speed sensor will allow the drive motor to start and run briefly before the error appears. If able to access the speed sensor wiring, measure the DC voltage between the speed sensor leads. Two of the leads will always read about 5 VDC. Two will toggle between 0 and 5 VDC as you slowly turn the speed sensor target. If both measurements are not seen, the speed sensor needs replaced. Some units have the speed sensor mounted on the lower PCA and the lower PCA needs replaced.
- Determine if the lower PCA is bad by swapping with a known good lower PCA.
- Determine if the interconnect cable is bad by swapping with a know good cable.
- Determine if the upper PCA is bad by swapping with a know good upper PCA.
I am getting a reading on the screen of "er 05" i
Precor Error 05, Key Depressed at Power Up
Probable Cause
1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
- Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
- Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
- Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Precor 9.31 stopped and error message 40 is displayed
Probable Cause
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Error 22 pca monitoring upper
Error Code: 22
Model: All Models
Error Description:
Possible Reason:
- Faulty lower PCA.
- Faulty upper PCA.
Recommended Action:
Error 42 on a precor treadmill
Error Code: 42
Model: All Models
Error Description:
Possible Reason:
Recommended Action:
My Precor 9.31 made a loud
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the speed sensing system indicating that the drive motor has started.
1. Drive motor brushes are bad or the lower PCA is bad.
