Question about Exercise & Fitness
My precor efx 546 makes noise like a squeaking in left pedal it seems I tried to tighten pedal but I the whole bolt and screw turn together and the other pedal makes no noise
Sportsmith LLC
  • Exercise & F... Master
  • 918 Answers
This squeak is normally caused by a bad bearing in the wheel. In order to provide you with the correct wheel, I will need your serial number. The following link will take you to our Precor EFX 546 page.
Repair Parts for Precor EFX 546 Ellipticals SPORTSMITH net
Posted on Sep 28, 2015
1 Related Answer
Anonymous
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
Precor EFX 546 Version 1 making clunking noise
Someone needs to look at this as noise issues can be from anywhere and anything.
877-805-1030
Book An appointment
Feb 11, 2014 | Precor EFX 546i Elliptical Version 4
Clunking noise precor 5.35
Hello
check for slop in the left and right hand side arms and foot tubes.
I'd tighten every bolt you can find.
GymWorld.net.au
Jan 09, 2014 | Precor EFX 5.35 Premium Series Elliptical...
How to repair a 546 efx precor
Assuming the buttons are working, the numbers change on the display, and the incline works, it may be the lower circuit board or the generator. If it is a very old unit, it may be the electromagnet or the data cable that connects the two circuit boards.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
May 08, 2013 | Precor Efx 546 Elliptical Version 2...
Precor elliptical keypad replace
Step 1:
please see the video for help in dissasembly the elliptical keypad replace.
Step 2:
please SEE the detail for dissasembly the console in elliptical.God bless you
Console
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Jan 07, 2013 | Precor Efx 546 Version 1 Lower Body...
Left side its sqeak when i peddle
My Precor EFX 546 elliptical trainer began squeaking when my weight was on the pedals. I thoroughly cleaned the track and wheels with Windex and then used my finger to apply a thin coat of teflon based lubricant (Tri-Flow brand) to the outer surface of the wheels. After 2 applications of lubricant, the squeaking has been eliminated completely. Hope this helps!
Sep 24, 2012 | Exercise & Fitness
There is a clicking sound periodically coming from the right pedal while I use the machine (Precor 546i). I tried tightening the bolts but the clicking persists. Any thought would be greatly appreciated....
It sounds like it could be a faulty bearing in one of your wheels, a worn ramp or a combination of the two. The following link will take you to our Precor page. Please reference your model and serial number. This will allow you access to the correct parts and manuals for your machine.
Precor Elliptical EFX Repair Parts Belts Wheels Pedals SPORTSMITH net
Aug 06, 2011 | Precor EFX 546i Elliptical Version 4
Can't find the serial number -- there is no tag or it has been removed. It's a precor efx 546, MANUAL not electric and I either need a new battery or a battery charger. What do I do without the serial...
Precor Serial # Locations Type of Unit Serial # Location Treadmills Located on the label near the power cord entry and on the frame under the left rear of the treadmill. Upright Bikes Located on the front stabilizer. Recumbent Bikes Located on the front stabilizer. Ellipticals Located on the front stabilizer. Stair Climbers Located on the bottom side of one of the foot pedals. http://www.sportsmith.net/
Jan 22, 2011 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
1,129 people viewed this question
Top Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
