Question about Precor 935 Premium Series Treadmill
My Precor 9.35 treadmill keeps shutting off. At first I thought this was due to use or it getting overheated. But, today I turned it on several times and it would shut off as I was walking on it. The switch on the front of the machine would turn off and turn off the machine. Is there an easy fix to this?
Posted by wachterc on
Anonymous
    New Friend:
  • 15 Answers
Is it on an extension cord? Take it off any extension cords and make sure it's on a dedicated 120v circuit. No other items on the circuit. Also, how old is it? Precor made a bunch of the 9.3x series from 2002-2005 with an aluminum tail roller that can cause problems. Check the back roller. Is is silver and non-magnetic? if that's the case, you have an aluminum roller and you need to contact precor. If you're the original owner of the machine, they should warranty the replacement of the parts, if not, you'll have to buy at the very least a running belt and new roller.
Posted on Jun 21, 2010
  • 1 more comment
  • Manny
    Manny Dec 26, 2013
    The front roller of Precor 9.35 is also made of aluminum. All that is needed is the replacement of the running belt and board. Check also the electronic control board.
  • Manny
    Manny Dec 26, 2013
    The rear roller has nothing to do with this problem. I had my 9.35 for 10 years before I experienced this power cutting off issue.
  • Manny
    Manny Dec 26, 2013
    If the rear aluminum roller is causing this problem, why you also have to change the front roller to a steel one. So, replace the running belt and/or the board. If that doesn't do it, the power control board should be the culprit.
Russ Wolterstorff
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
There was also a problem with the MCB - the circuit board that controls the motors. It would cause the breaker to trip prematurely. Call Precor to see if your MCB or roller(s) are eligible for upgrade.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Posted on Dec 02, 2014
Sportsmith LLC
  • Precor Master
  • 918 Answers
Chances are the treadmill started by shutting off in the middle of a workout and has gradually gotten to the point that it will not run long, or turn on at all, in some cases. This is most likely caused from a worn deck and belt. If the belt and deck is not routinely waxed, it wears down and causes friction. This friction builds up heat which can fry your electronics. The machines circuit breaker shuts the machine down to protect the major electronic components. This protective measure, built in by the manufacturer, will only help for so long. After a few times of shutting down due to the heat, it actually does damage to the electronics. The result and correction usually ends up being a new deck, a new running belt, and in most cases that have gone on too long, the motor control board. I am attaching a link for the service manual for further information. http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Consumer%20Treadmill/9.35%20(serial%20code%20A996,%20AMPN).pdf Precor Consumer Treadmill 9 35 Parts SPORTSMITH net
Posted on May 12, 2014
Circuit Board Repair
    Problem Solver:
  • 18 Answers
The aluminum rollers gave off a black dust. This dust gets under the running belt and creates drag on the belt. As that drag (friction) builds during a workout, the motor has to work harder, and eventually overloads the board. Replace the aluminum roller(s) with steel, replace the running belt, clean and flip the deck. If your still having issues, you've damaged the lower board and it will need to be repaired or replaced. CircuitBoardRepair.net repairs them for about $100.
Posted on Feb 26, 2020
jhremke
    New Friend:
I have the same issue - about 20 minutes into my workout it does the same thing - I have to turn the front switch on. Then after it happens once, it only takes about 4 minutes and it would do it again. I would never suspect the back roller to cause the power switch to turn off.
Posted on Jun 04, 2013
When push quick start button, why does it display Erro 30 and doesn't run?
Hi There....This is a great message for ALL PRECOR 956/966 owners. This failure usually relates to a "communications" error between the upper and lower electronics. This particular failure is a direct result of a failed IFT drive module, or the lower drive "box" that is made by Advanced Drive Technology. The brains of this lower controller has failed and cannot "talk" to the upper board anymore due to several failed parts inside this box. You are lucky to have this failure arise over a fatal blow-out. Now replacements thru Precor or a distributor will be $550+ and are usually low stock items at places, but you can get repairs and exchanges of this Precor IFT drive by emailing gregATbuyfitnessrepairpartsDOTcom for much less than all other vendors. Currently these IFT drives are 380 exchange and 199 repair and turnaround is one day. Good Luck!
Feb 11, 2016 | Precor 956i Experience Series Treadmill...
Why does my precor C954i keep shutting off
It must have been crossing its excess weight limit..
Jun 26, 2014 | Precor C954i Commercial Treadmill
How do I fix an ERR70 message on the display of my 9.21 treadmill.
Precor Error 70, LPCA Not Read Probable Cause Incorrect or missing software in the LPCA
Corrective Action Test with a known good LPCA Precor Error 70 LPCA Not Read AMT12 Only
Jan 05, 2013 | Precor 9.21 Treadmill
Precor 933i belt error
Please read my personal TIPS for treadmills and test it.
However LUBE inmediately the deck belt, this happen because the lack of maintenance by 5 hours aprox, So the system protect itself for electronic system and shut down.
2) LUBE the rollers bearing too.
3) Test the main motor bearint, measure the input voltage motor, if there are the motor is faulty. Repair. see my personal TIPS
God bless you
Nov 15, 2012 | Precor Exercise & Fitness
SPEED ERROR ON PRECOR 927 TREADMILL
I had the speed error on my precor 9.23. When I opened it up I found that there are two little round magnets on the belt pulley with a sensor mounted nearby. This must be how the computer know the speed of the treadmill. I noticed that there were several little metal shavings stuck to the magnets. Not sure where they came from, hopefully not another problem. However, I removed the metal shavings from the magnets and everything worked fine again. If anyone else has the speed error it might be worth a look to see if its the same problem.
Jul 02, 2012 | Precor 927 Treadmill
Precor 9.27 Control Portion Not Turning On
1) Reset the c.breaker from your house
2) See the c.breaker or blown fuse in your treadmill see the block diagram +c. diagram
3) Try again, and proof.
4) Test the main switch from treadmill, and replace if necessary for OPEn, see the diagram how to do it.
God bless you
Jun 10, 2012 | Precor 9.27 Treadmill
I am looking for a shroud cover for my Precor M9.21 Treadmill #FSL17I0001
Here is a motor cover for several versions of the Precor 9.21. Not sure if that's what you're looking for or not but maybe that will be useful.. you can click on any of the equipment models listed there to browse a complete parts list.
May 22, 2011 | Precor 9.21 Treadmill
Power keeps cutting out when clients are running on it.
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Parts for 952i 954 954i 956 956i Treadmills SPORTSMITH net
Apr 16, 2011 | Precor C956i Treadmills with HR /...
Broken motor cover
There are a few different versions of the Precor 9.21 treadmill but FitnessRepairParts has a motor cover that it says is used for several of the models: http://www.fitnessrepairparts.com/cart/ViewItem/5005569
Oct 05, 2010 | Precor 9.21 Treadmill
Key STuck Error
The key pad is not functioning properly thus this error is flashed you will need to replace key pad. Since I don't know where you are then the place to get the part is from precor directly the will ask Model & Serial #s
WORLD HEADQUARTERS20031 142nd Avenue NE
P.O. Box 7202
Woodinville, WA 98072-4002
T: 425-486-9292
T: 800-786-8404
www.precor.com
Jun 30, 2010 | Precor C954i Experience Treadmill
Precor 935 Premium Series Treadmill Logo
3,975 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
