SOURCE: Fan runs but no cool air on both freezer side and cold side
If you hear the compressor try to start then click off, you probably have a bad compressor or a bad relay. If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge. The relay is only covered for a year. With it being a Maytag, I bet it is compressor. There have been a few models with control board problems that have caused this symptom, but that's not likely to be your problem.
SOURCE: the freezer is cold but inside refrigrator is not cool.
Hi...
In this problem you need to check this following:
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Next, see if the compressor motor is running
The
compressor is a football-sized case with no apparent moving parts. It's
on the outside of the refrigerator at the back near the bottom. If it
is humming or making a continuous noise and your refrigerator is still
not cooling, there may be a more serious problem with one or more of
several different components, we recommend contacting a qualified
appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
Cooling is poor
For
an overall understanding of how refrigerators should work, read about
refrigerators in the How Things Work section of our website. A
refrigerator or freezer that is cooling, but cooling poorly, may have a
problem in one of several areas:
Evaporator coils
Condenser
Poor
cooling is often the result of a heavy frost build-up on the evaporator
coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils
Poor
coils. You can't see these coils without removing a panel on the inside
of your freezer. A sure sign that there is a build-up is the presence
of any frost or ice build-up on the inside walls, floor, or ceiling of
the freezer. Such a frost build-up usually indicates a problem in the
self-defrosting system or damaged door gaskets.
The refrigerator
is supposed to self-defrost approximately four times in every 24 hour
period. If one of the components in the self-defrosting system fails,
the refrigerator continues to try to cool. Eventually, though, so much
frost builds up on the evaporator coils that the circulating fan can't
draw air over the coils. There may still be a small amount of cooling
because the coils are icy, but with no air flow over the coils, cooling
in the refrigerator compartment is quite limited.
Here's an
inexpensive, though inconvenient, way to determine if the problem is
with the self-defrosting system. Remove all of the perishable food from
the refrigerator and freezer, turn the thermostat in the refrigerator
to Off, and leave the doors open for 24 to 48 hours. (Be sure to have
several towels ready in case the melting frost and ice causes the drip
pan to overflow). This allows the refrigerator to defrost "manually."
When the frost and ice build-up has completely melted away, turn the
thermostat back to a normal setting. If the refrigerator then cools
properly, it indicates a problem with one of three components in the
self-defrosting system:
If
it still does not cool properly, there may be a problem with the
refrigerant level or the compressor. You may need to consult with a
qualified appliance repair technician to further diagnose the problem
Condenser
Self-defrosting
refrigerators all have a set of coils and a cooling fan, usually under
the refrigerator, that need to be cleaned regularly. If these coils get
coated with dust, dirt or lint, the refrigerator may not cool properly.
The coils may appear to be a thin, black, wide radiator-like device
behind the lower kick-panel. To clean them, disconnect the refrigerator
from the power source, use a refrigerator condenser brush (see the
Appliance Accessories section) and your vacuum cleaner to clean the
coils of any lint, pet hair, etc. You may not be able to get to all of
the condenser from the front, it may be necessary to clean the
remainder of the condenser from the rear of the refrigerator.
Good luck
Regards
PCmania
SOURCE: Hello, I have a side by side Model # MSD2758GEB
You have a defrost problem. You will need to thaw out your unit by turning the fridge off for a day or night before you install the new parts. if you will give us a call, we'll be sure to send the right parts out to you right away so you can repair this unit. We hope this answers your questions and we hope to be able to work wit you further. :>)
Testimonial: "You don't know what the hell is going on, its better you give up this occupation. You are trying to fool people. I wrote that there is no ice jam."
SOURCE: Freezer working but Fridge not cooling...
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp.
The problem could be the electronic control if
you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
