You have a defrost problem. You will need to thaw out your unit by turning the fridge off for a day or night before you install the new parts. if you will give us a call, we'll be sure to send the right parts out to you right away so you can repair this unit. We hope this answers your questions and we hope to be able to work wit you further. :>)
Testimonial: "You don't know what the hell is going on, its better you give up this occupation. You are trying to fool people. I wrote that there is no ice jam."
I am sorry that you such an angry person. I just wanted you to know that although I may mistakes from time to time, that I do in fact know what I am doing the majority of the time and fooling people is not what I try to do. I apoplogize that I misdiagnosed your problem, and am shocked how angry people can be.
May God bless you and keep you.
Ella from Accurate Appliance Service
I'm sorry that you are having a problem, and it is our goal to assist folks with their appliance issues. It's what we've been doing for 30 years. We sometimes get angry folks like you in our business and we still attempt to resolve your issues. We hope that you have a happy day and we only wish great things for you.
Ella Watson - Accurate Appliance Repair
Try this...there's a damper door at the top of the fridge, the cooling happens on the freezer side, the damper opens and closes to control the fridge temp. Access it and prop it open with a paperclip and see if your temp in the fridge drops back down overnight. If it does, you'll need a new damper/temp control assembly, available at a couple of places online for relatively cheap. I have the same fridge, it happened to mine, too.
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Top of Form
Suspect the fault can be the defrost timer to confirm shut off the fridge, after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
