HI,
Direct Code Entry:
Find the code your device.
1.Press and hold "CODE SEARCH".
2.Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3.Enter the 3-digit code number.
4.Release "CODE SEARCH".
With the device on, press another button to test. If it does not work, repeat steps 1 thorugh 5 with other codes.
follow the below steps to set remote with out codes
Code Search:
1.Turn on the device you wish to control.
2.Press and hold "CODE SEARCH".
3.Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5.Press ON/OFF repeatedly until the device turns off.
6.When the device shuts off press and release ENTER.
Try using the remote. If it does not function repeat steps 1 through 6
To get the code please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Thanx
