Dryers Logo
Question about Hoover Dryers
My Hoover 3530D clothes dryer has stopped blowing
My Hoover 3530D 3.5kg clothes dryer has stopped blowing warm / hot air, just cold..
Posted by karen_blackh on
Anonymous
    New Friend:
  • 112 Answers
Thermostat or element burn out.
Posted on Jul 24, 2010
1helpful
Where is the reset button on a Hoover 3530D clothes dryer
Doesn't have a reset button. You need to verify power to unit first. If you have power, most likely your thermal fuse has blown.
1helpful
After replacing the thermal fuse one my electric kenmore dryer, there is heat but clothes are not drying and is blowing out cold air
Might be the timer. Might just need cleaning. Take a look at my home video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Hoover dryer 3530d tries start only moves for a second
You will need to check the motor for any lint buildup and also the exhaust blower fan for any garment that may be hung up.
1helpful
I have a hoover dryer model 3530d. I have to open it and try to turn the drum over and over before it will start to turn. What is the problem. Is it worth fixing or should i just buy a new one
the belt maybe stretched or the motor, you will need to open dryer and look at the motor and belt, idler arm, drum roller and glides, this website should assist you, Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Jun 14, 2011 • Dryers
My dryer is not getting hot its not drying clothes even when they have been in for 3 hours
Is dryer getting warm at all. If it is your heater and t-stats are fine. Make sure it is exhausting to uotside properly. Turn dryer on and go to outside exhaust. you should leel air coming thru pretty good. If low air flow pull dryer from wall, disconnect hose at wall and using leaf blower blow the exhaust out to the outside. Impotant thing to remember is blow from behind dryer at the wall to the ouside. Not outside in. Also, electric works better than gas blower due to exhaust fumes caused by gas leaf blowers.
1helpful
HDV6UK...clothes are warm but not drying!! help
Vent going away from the dryer is stopped up full of lint or the vent tubing is collapsed causing the hot wet air to remain in your dryer.
1helpful
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
3helpful
Dryer blowing cold
Check the following to address this issue.
Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Please rate and have a great day:)
1helpful
2answers
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Top Hoover Dryers Experts
Marvin
Marvin
Paul Carew
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
