Question about Hoover Dryers
It may be overheating. Clean exhaust duct and clean lint from filter and from around the motor.
Posted on Apr 28, 2019
SOURCE: Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Posted on Aug 15, 2007
SOURCE: Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Posted on Oct 14, 2007
SOURCE: Duet Dryer will not start, Press control on, Start, then it beeps
try tripping your circet breakers dont assume that just because it lights up both lines are working you can have a partial tripped breaker and just be getting 110 to the drier its easy enough to just go ahead and reset the breakere if that dont work get back to me
Posted on Dec 28, 2007
SOURCE: Maytag MDG7600AW Gas Dryer heat starts and then stops
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance. Clicking on the underlined links will take you directly to that page.
If your dryer doesn't heat properly, check this:
Venting restriction: Disconnect the dryer temporarily from the vent. If the flame stays on for a longer period, you may have an air flow obstruction to the outside.
Gas valve coils
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Also, in your case, the coils may work fine initially, but heat build up can cause the coil(s) to malfunction and when they cool down will work again.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3479&PPStack=1
This link will help you with disassembly and diagnostics diagrams.
http://www.repairclinic.com/0100_17.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
SOURCE: Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Posted on Oct 26, 2008
