Every time i turn on my playstation it starts for about 2 seconds then turns back to stand by but the red light is now flashing what is the problem and how much will it cost to repair please
Follow the procedure below to fix the problem on your ps3,
1.
Turn off Playstation®3. 2. Hold the power button down; the system
will turn on and turn off once again. 3. Once the System has been
shutdown, re-press you finger until you hear 2 consecutive beeps 4.
When you hear the 2 beeps take finger off power button. 5. You will
be prompted to plug in your controller via USB and then hit the PS
button 6. The Recovery menu will pop up.
The current Recovery
Menu supports: • Restart System: Restarts the PLAYSTATION®3 System. •
Restore Default Settings: Reset all system settings back to default. •
Restore File System: Checks for corrupt/missing system files. •
Rebuild Database: Rebuilds the OS for the PLAYSTATION®3. • Restore
PS3 System: Fresh restore; Deletes everything and starts from Scratch. •
System Update: Update the PLAYSTATION®3 System.
1)Turn off your playstation 3. If you think your ps3 has been
caught by the heat, then wait at least 20 minutes and put it back on
again 2) Check if there's any loose cable. 3)
Try to put out your playstation's hard-drive, and put it back in. You
might want to repeat this 2-3 times for better results.
If this
did not work Send your playstation back to Sony
Sounds like YLOD before the red light flashes it probably starts up for like 2 seconds then the light changes to kind of a yellow color then the red light flashes. If that's the case its a hardware problem. First try letting it cool off - if no luck try taking the hard drive out - still no luck if under warranty send it in - if out of warranty and you cant pay the 150$ you can try to fix it your self at this point it could be your power supply (ebay 50$ - 80$) or reflow the mother board lots of videos on youtube for that.
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
