Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
Posted on Oct 19, 2017
Lawnmower stalls. My electric black and decker lawnmower stalls out, slowly spinning to a stop. It started last year (it's just over 2 years old) and began only when it was getting clogged. It progressed to happen much more frequently. It now happens every 2 minutes. It restarts after a couple of minutes, often after I jiggle the srtart handle.
1 Related Answer
Anonymous
  • 3640 Answers
  • Posted on Nov 06, 2011
SOURCE: two-year-old Black & Decker 19"
if its not in the cord. it may be the brushes in the motor. if they are worn down and not hitting armature. motor will not run. good-day !
2answers
Lawnmower dead
Is the gas tank is empty. Old gas can also lead to problems starting, There is a product you can add for old gas issues see your DIY or hardware store this happens often if you have last season's gas in your mower, drain your fuel tank and fill with fresh gas. some other thoughts might be Loose, Dirty or Disconnected Spark Plug Check it out, clean off debris, re-connect and tighten. Dirty Air Filter Clean or replace. Fuel Not Reaching the Engine Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
1helpful
2answers
My Black & Decker Leafblower Leaf Hog BV4000 type 2 quit running suddenly while using. It had run about an hour, was not warm to the touch and is 2 years old. Is thuis a common problem and what might
Same thing here after i did my neigbours yard!!!! i found out it was the switch the latch that moves it wont I am trying to work a away round it hope this helps
I have an older Black & Decker electric lawnmower
Does the mower sound like it is running at full speed? Have you double checked that the blade was not installed upside down?
1helpful
Two-year-old Black & Decker 19"
Electric Lawnmower stopped working.
You were NO help at all. I asked for a location to have an electric lawnmower repaired in my area. You gave me a source 2500 miles away. Obviously I cannot count on assistance through this site. What happened to REAL PEOPLE who can offer some intelligent reply? If I could repair a lawnmower, why would I need to ask you?
1helpful
2answers
B&D MM850 starts then stops a few seconds later, then won't start
I was having a similar problem. I tried starting it up with the switch case open. I saw a very tiny puff of smoke come out of the switch. I replaced the switch and it was fine.
Black and decker mower switch wiring
I have a Black and Decker Electric mower #M2370, which I would like to use this year before moving to a condo. Last year, the mower was stopping and starting depending on how the lever was positioned. I suspected the wiring so I removed the on-off switch lever. The wiring appears intact. Part of plastic inside the lever maybe broken. Can i use the mower without the lever by just pushing the black button?
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
