20 Most Recent Black & Decker Hedge Hog 20-Inch 2.8-AMP Dual Action Hedge Trimmer #HS1010 Questions & Answers
fuse probably went in the plug/extension-replace plug and mend the cable or replaceit
Black & Decker... | Answered on Sep 25, 2018
I'm not familiar with your machine, BUT... that description of symptom sounds suspiciously like a bad/poor electrical connection.
The problem could be in many places:
  • plug
  • cord
  • switch
  • brushes
  • internal electrical wiring
The "solution" to this problem is for someone who knows what s/he is doing, to troubleshoot the defective machine, determine the defect, and properly repair or replace the defective part.
Black & Decker... | Answered on Sep 12, 2014
Your blades are stuck together.
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
Black & Decker... | Answered on Jun 22, 2014
The only thing that i can think of is that somwhere along the length of the cable it has either atiny nick or it has been pulled so that when you hold it in a certain way it works . It is most likly near the tool end rather than the plug end.Only way to find it if it is is trial and error turn machien on and bend cable till it cuts out
Black & Decker... | Answered on Dec 03, 2010
Go to this Free Black and Decker website to obtain your manual.
http://www.blackanddecker.com/CustomerCenter/Manuals.aspx
Black & Decker... | Answered on Nov 13, 2010
Do not try and replace the blade.
They are not ment to be replaced let alone even resharped
If it can not cut any more time to buy a new model
Black & Decker... | Answered on Jul 26, 2010
Check the power wires that connect to the motor. My 18 inch B&D hedge trimmers both had loose wires at the motor that had to be re-soldered. You will need to open the trimmer casing to get to the loose wires, if that is the problem.
Black & Decker... | Answered on Jul 14, 2010
Black & Decker Hedge Hog 20-Inch 2.8-AMP Dual Action Hedge Trimmer #HS1010 Logo
37 questions posted
Top Black & Decker Garden Experts
Marvin
Marvin
Mike
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Garden
Most Popular Question
cutting blade 8124 04 type 5
  • Garden
