Most likely a noise from the freezer fan motor. Possibly the plastic blades are cracked or a piece broke off causing an off balance condition. They could also be rubbing some excess ice back there.
Check to see if your fan is rubbing against any frost that has build up in the freezer. If so you might have to shut off to drain off the frost and check the timer, heater and thermostat for failure. After the fridge had cleared of frost you can switch on to see if the fault of moise has changed. If not check the fan or compressor mountings for noise. Hope you try this out. Good day
Hi, Remove the rear inside freezer panel and you will be able to see the evaporator fan motor. The fan motor is what is squeeling.
I hope this helps you. Please let me know if I can assist you further.
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
